Corded impact recommendations?
rapyoke
Northern Virginia
I am looking to buy a corded impact for working on my car, but I am sure I will find other uses for it around the house. :)
I would like to try and spend as little as possible but wouldn't mind paying more for a quality product. Ideally it would be under $200, but if there's a much better product for $220 I certainly wouldn't be opposed to it.
I have been looking at the following, any input/experience would be much appreciated:
http://www.amazon.com/dp/B0009HM5OI/?tag=atomicindus08-20
http://www.amazon.com/dp/B0000647GA/?tag=atomicindus08-20
http://www.amazon.com/dp/B00005T81G/?tag=atomicindus08-20
http://www.harborfreight.com/1-2-half-inch-electric-impact-wrench-45252.html
Danglerb
SoCal
The HF is cheap, heavy, noisey, but seems to work fine. I suspect you will need to use one a LOT before spending 6x as much seems like a smart move.
Prices vary a LOT, mine was close to $30 on sale with a coupon.
gtivr4
Vermont
How much torque do you NEED? Are you just removing lug nuts? For $200, I would go for a cordless setup which gives you more flexibility with not that much sacrifice in torque. For example, my 19.2V Craftsman does about 200 lbs-ft, and takes off lug nuts just fine. It was well within your budget.
