Corded Multi Tool
rpearlberg
Fairfield, CT
I have some gift cards for Home Depot and I want to get a multi-tool.
I'd like to stay around $100-$150.
Which one? Dremel, Ridgid? Others...
This is for home projects, probably be used a couple times a month...
DHS
Central FL
I only have a Ridgid cordless, but it is cool that you have different attachments for it.
Richard Cranium
central Washington
I have a couple of corded dremel, with a box full of attachments but don't use very often. But when you need one they are great. I pick up lots of parts and pcs at yard sales....
Hpozzuoli
Rhode Island
My dremel gets a ton of use. Next to saying get a cordless impact at Home Depot my next suggestion would be a dremel. I would get dremel brand. I have corded, but I am sure cordless is even better.
R
rpearlberg
Fairfield, CT
Thanks. I get decide which one to buy!! I have HD gift cards, and also Amazon gift cards. Dremel? Makita? Bosch? Which model?
sberry
Brethren, Michigan
I don't know the first thing about them and just bought one from Menards. They had a 20$ one, a 40 and then the branded ones up from there. I bought the 40, looks and feels like an exact close with a different color jacket. Current draws are the same.
Hencini
I was researching this a little while ago. A lot of guys on here recommended the Proxxon. I forget which model. It was right around $100 at the Depot, tho.
Hpozzuoli
Rhode Island
Dremel multi pro 395. I have used the flexible wand maybe a handful of times. Nice to have but not a deal breaker. I have a drawer full of attachments. I can't stress how useful this thing is for me.
sberry
Brethren, Michigan
Oh,,, btw,,, the Menards deal has variable speed if it matters. One of the reasons I chose this one was at 40$ it changed the debate and the incentive. I cant say,, havnt got it yet.
Vvmvbb
CT
Proxxons sure look nice. If my ~25 year old Dremel ever quits...
rharman
SoCal
I'm confused.... :dunno:
Are we talking rotary grinder (Dremel) or oscillating multi-tool (Fein)??
donvito
Same here. If you want a rotary tools (Dremel) I can recommend a Black and Decker RTX. Got mine with the accessory kit and swapped the chuck for the Dremel model. Been kicking for almost 2 years now with almost daily use.
If it's an oscillating multitool... I'm in the market for one as well and have been eyeing Fein (made in Germany) for a while now.
:beer:
dogdog
if it is the dremal rotary tool, COSTCO / sams sells one for about $20 it is great comes with all the accessories looks exactly the same as the HomeDepot unit that cost $59 except for the packaging differences...
if it is oscillating multi-tool, nothing beats the Fein multimaster. Just their accessories are too expensive, others are making them compatible for it now (sears / HF blades are compatible with it). the Rigid unit was nice when testing it on their display. But not as good as the Fein.
Mr. Brooks
I have the bosch oscillating tool 3.0 amp version, got it as display item plus 25% HF coupon so ended up at around $60, but I completely love it and the 15 or so blades it came with . I got the blade adapter for $1 so I can use any blade I find.
Modern Jess
Bay Area, California
I used to have a cordless Craftsman oscillating multi-tool, but it never seemed to have enough "oomph". Traded it in on a corded Dremel MultiMax MM40, and I'm very happy with it. Plenty of power, good selection of blades / accessories. It's one of those tools that can do a bunch of odd jobs that nothing else can really do, and you wonder how you ever got along without it.
getahammer
Central Ohio
I have a H.F. clone I bought at Menards for ten bucks. It's ok, but I've used a friends Dremmel, and it's got so much more torque. I will say this : Don't skimp on the accessories. Some are downright dangerous.
pauls_workshop
Indiana, USA - Underappreciated Place to Live!
I got the Menard's Performax variable oscillating multi tool for $30 at BF (also can be had on clearance now for same price if your store has any left). It is very good, smooth and powerful and a great deal for the price with a very full set of complimentary blades. The HF variable speed is the same as well (earlier version was *exactly* the same as the earlier Performax brand one). The cheaper HF non-variable work too but are much louder and vibrate all over more (not just on the tool end where it is supposed to). Dremel, Bosch, Fein, etc. make better ones that are also all more money, some alot more money. I like the $30 one I got and can get a couple more of those for the cost of one of the others if I wanted to. I no longer like the cheapest HF ones as they are very loud and not as fun to use for long periods due to the vibrations. Variable speed is nice.
For Dremel rotary type tools, Dremel is king of course but also biased towards very low torque ability with very high speeds needed to do the job. Some brands provide more torque to do the job at lower speeds. The Black and Decker is a good high torque type, as is a Ryobi type. I have one of each. Variable speed again is nice to have. I also have some Dremels that spin very fast, but any digging in (high torque) will break those bits or stop it in its tracks, so I consider those not good for every type of job. The B&D or Ryobi don't do that, but drive right in without slowing down much when torque is needed and are less likely to break bits as a result. I like that style tool better most of the time. Many more expensive options there too like Bosch, etc. Depends again what you want to do with it, your needs, and your budget. As a DIY homeowner type, who also likes to have good tools that are nice and work well, I won't spend more than about $40 for either of these type of tools, and don't need to anymore today. There are good low cost options out there. - Paul
cheechi
Triad, NC
I have a fein 250. They are damn good. Bosch is also in that category. That being said;
Unless you're going to be using it weekly or more the HF or similar cheap ones are just as good. Personally I would not get the Dremel, PC, or Dewalt branded oscillator since their blades are nonstandard. I think the Rockwell one is that way also. The way I look at it, why spend money on the middle of the road ones? you have good at the cheap and expensive ends of the spectrum, the rest are 'me too' tools.
Bosch makes good blades, as does Fein although both are expensive. Imperial makes a good balanced blade for cost/cut and HF blades aren't terrible in this case. Some tasks you will want to spend more per blade some you won't need to. It will be based on your experience and use where you want to cheap out or not.
For a rotary tool, Dremel or Proxxon if you want nice, or anything just to get you out the door. Some dremel bits are worth their premium but that's a whole thread worth of discussion right there.
ishiboo
Oshkosh, WI
I've had good luck with the Performax as well, mine is several years old and has been flawless. My Bosch cordless is great as well and comes in VERY handy, I almost never reach for the corded now.
With a HD gift certificate, I'd probably buy the Milwaukee M12 variety.
James_B
Nova Scotia, Canada (started in Brisbane, Australi
I have a Dremel MultiMax corded oscillating tool and it gets a lot of use. Was invaluable for shortening door trim without having to remove it when we were putting hardwood flooring down to replace laminate.
The wife was having difficulty constructing a gingerbread house last Christmas, so after many failures, I showed her how to use the oscillating tool to cut out the shapes she wanted from slabs of cooked gingerbread. She was so hooked on the tool for doing that kind of stuff that she's now got a Canadian Tire Mastercraft cordless oscillating tool amongst her kitchen gadgets.
skruft
Still not sure whether you mean a rotary or oscillating tool.
For a small portable rotary tool I have always used Dremel but I think it is not robust enough for daily use. For a fixed one I have used Foredom, which last forever.
For an oscillating tool I have a Fein and had a Bosch. Both work well.
IndyGarage
Indy
I had a Ryobi corded rotary tool that I didn't pay much for and used the heck out of for probably 10 years.
It finally died and I replaced it with a Dremel brand which is total junk. I would buy the Proxxon if I needed one now.
I mostly use my Milwaukee M12 cordless rotary tool if I need one these days.
At one point I had a flex cable for my Rotozip tool and I was able to use it like a Dremel, but the flex cable broke and I never replaced it. I liked that setup because the Rotozip motor has a lot of power.
Which makes me think something like a Foredom cable tool might be the best.
bcradio
New Mexico
Bosch for sure if you plan on using it a decent amount. Their blades are very nice too.
I still don't understand how people can get away with using the HF coupons at HD and Lowes :headscrat
pauls_workshop
If you liked that Ryobi rotary tool, check out the new Black and Decker. It is like $20 or less on sale and has variable speed and good torque like the Ryobi had. Ryobi's can also still be had from cporyobi.com I think as a combo with something else. The Ryobi is a great version of this kind of tool. B&D is getting respect for this too - see the Amazon reviews for it. You could buy 4 or 5 of these for the comparable dremel or bosch versions out there. BTW if you have any of the Ryobi one plus 18 v cordless tools, their super dremel rotary tool in that line up is one of their best tools ever. Very good and has almost as much power as a corded rotozip has. I use that when I need more power than the corded Ryobi or B&D "traditional" smaller dremel like rotary too. - Paul
sberry
Brethren, Michigan
Paul, that was my take from store comparison, it looked and felt good, like the real deal. The Performax is what I got also, havnt used it yet.
finn
The UP, God's country
Performax from Menards here. Paid $40 or $50 on sale. Works fine...good enough that I wouldn't pay more for some other brand. I resisted buying an oscillating tool until I needed to make a cut to replace some water damaged subfloor with limited access. Since then, I've found several uses for it. I've been pleasantly surprised. I don't think it's worth dumping a lot of money into one though, as most cuts realistically take 30-45 seconds. That's not a lot of run time, even over a number of years
I still have my 1966 Dremel rotary tool with the steel case and original flyer inside. Works well, much better than my newer battery POS dremel. Also have a Craftsman that I seem to have inherited from my son (He must not need it because it's still in my shed). Works ok, but the plastic sure doesn't feel as nice in your hand as that old 1966 Dremel.
pauls_workshop
I got my first one just 3 years back and could *not* live without an oscillating tool now. It is the greatest tool ever for drywall work, especially tricky cuts. Be sure those old dremels don't have worn out bearings. Never use a dremel type tool with any wobble to it or worn out bearings as very dangerous then. Had that happen to one of my older ones once. - Paul
