Corded Multi Tool
rpearlberg
Fairfield, CT
Dremel 3.0-Amp Multi-Max Tool Kit MM45-01 ($129)
vs
RIDGID JobMax 3-Amp Multi Tool Starter Kit ($79)
vs
Makita 3-Amp Corded Multi-Tool Kit TM3000CX5 ($99)
Which one should I get?? This is just for home use to keep in the basement for when i need it.
lotsoftools
Inland Empire
I bought the Harbor Freight one because I didn't know if it would be something I would like to use and it was super cheap. I found out how handy it is and want to upgrade. My recommendation is to find out which one has the most options on the attachments and are easy to get. The attachments don't interchange between all the different brands, and some are harder to find than others.
zkling
I've ask much more out of my dremel than it was designed for (carbide burrs and abrasives in metal). Once I had a problem, sent it into dremel, they repaired it free of charge. I would not hesitate to purchase again.
ez-duzit
Marina del Rey
I have the Fein Supercut and Multimaster. Love these tools!
Supercut is my go-to machine whenever flush cutting is required, where other saws won't fit, and where free-hand starting a cut mid-panel or when a thin kerf is essential. Plunge cutting is very easy. Blades are extraordinarily expensive. The fine tooth, Japanese-style, wood blade is the best one to use on veneered plywood and anywhere that chipping must be minimized. Use bi-metal blades for cutting metals.
Multimaster I usually leave setup with the triangular sanding pad.
thebeekeeper1
Illinois
Having seen, used, and handled several I ended up with the Fein Multimaster. They are reasonably priced on Ebay. Not what you asked, but Fein OWNS that market. Quality is worth it. Buy once, cry once, etc. :)
Letsgobowhunting
Village of Clinton, N.E. Ohio
I have a cheap one and beat the heck out of it. It works well. I have heard that Fein is the best though. I would like to get a cordless version next.
lars
PA
I tried out a few at Home Depot's in store display. I went with the Makita as it did the best job of not transferring vibrations through the tool. Basically, my hands were vibrated the least on the Makita of the few I tried. I've been pleased with it so far.
MN4x4
Minnesnowta
I have the Fein MultiMaster as well and I and think it's the best you can get.
Problem is I bought it years ago and have hardly ever used it. I suppose I should consider selling it...
stage20
pcola FL
There are adpters you can get to adpt tools and attachments. I hve a hf one and it works great. The only issue is if you are bearing down the vibrations will losen the screw no matter how tight it is
Mr. Brooks
I have the 3.0 amp Bosch, love it. Use it for all kinds of things Im sure it wasn't designed to do...I just cut a carbon fiber n2 tank in half with it...
pauls_workshop
Indiana, USA - Underappreciated Place to Live!
If you don't live in one of those fancy places, like along the coasts, I like the Menard's Performax variable speed one. It is not 3 amps, but works great and was like $30 with tons of bits. Older one was same as HF one. HF variable speed would be very similar to this. Best bang for the buck. I have a cheapie HF one also and just too rough and loud now that i use these alot. Best tool ever for drywall work or anything else that just can't easily be done any other way! Like weird controlled precision cuts in tight spaces that become easy and not dangerous with this type of tool. - Paul
R
rpearlberg
Fairfield, CT
Thanks for the info. My HD doesn't have them so you can test them...
Right now I have all three, but can't decide which one to keep before I open them!!
This tool won't be used often, but I want a good one for when I do need it.
Monte
Germany
Wait for the all new Fein MultiMaster :)
