Corded power tool storage ideas?
TorqueWrench
KC, MO
So how do some of you guys store your corded (and cordless) power tools. I have mine just thrown in one of my cabinets. Angle grinders, bufffer, drills, heat gun...etc. Post some pics if you got them.
Thanks.
boiler7904
NW IN
Each power / cordless tool gets stored on a shelf in its case along with any accessories that will fit in the case.
If a tool doesn't come in a case, I find a metal or plastic toolbox that fits the tool and its gear.
It helps me avoid a tangled mess of cords and lets me find all of the parts, pieces, wrenches, etc. when I go to use the tool.
eschoendorff
I do sort of the same thing.... or I put case-less tools in those tool bags that you get with cordless sets...
wilbilt
NorCal
I built a "poor man's Lista" out of an old computer rack. It was already on casters. I turned it sideways, and attached a vertical 1x2 strip in each corner using the prepunched rack mounting holes.
I screwed some ebay-procured drawer slides to the 1x2s and built some drawers from scrap plywood and OSB. The upper drawers are deep enough to fit drills, jigsaws, a reciprocating saw in it's case, etc.
The bottom drawer holds a circular saw, router in it's case and other things that don't fit in the top drawers.
It's not pretty, but it works, and cost me about $10 because I already had most of it lying around.
klswvu
Morgantown, WV
I have a few old steel school lockers with shelves from top to bottom. Each slot is the right size for a power tool.
wilbilt
NorCal
I work for a school district, and keep trying to get "dibs" on old lockers as they are replaced. Unfortunately, somebody always beats me to it. They are a hot commodity, lol
Charles (in GA)
50 mi south of Atlanta
The old gym clothes wire basket shelves? I have four of them, shelves are spaced somewhat closer than a normal metal shelves. They had tabs on the shelves to lock the wire baskets to, I removed them, bolted pairs of them back to back, mounted them on angle iron frames with casters. One is tools, power tools, cased tap and die sets, battery chargers, funnels, etc. The other pair is for aerosol cans and small parts such as tywraps, light bulbs, etc.
Charles
1320stang
Edmond, OK
It seems that the nicer corded tools used to have a wire bail attached near where the power cord went into the tool, though circular saws are the exception. I tend to wrap the cord around the tool after giving a loop near where the cord enters the tool. Not many cords to deal with. When I replace a cord, I've been making them short, long enough to tie a 'knot' with the extension, but that's about it. I kinda like how some of the electric weed whackers and bush trimmers have no cord, but the extension just plugs into the tool. The drawback is the large housing end and plastic spear that sticks out to help retain the cord.
russlaferrera
Central Virginia
I use toolboxes, that fit that item and all the needed parts/supplies ie: 4 1/2 grinder has extra disks, flap disks , changing wheel wrenches.
I also have toolboxes for electrical stuff such as wire nuts, plugs, switches, tape and elect. tools. It makes it easy to do any elect work as everything that is needed is there.
