Cordless battery powered auger
jrsavoie
North east Illinois
Does anybody have a recommendation for a cordless / battery powered auger?
Like for fence posts?
Reversible would be nice, if they make such a thing.
6" diameter would be plenty.
Anything bigger than the 3" bulb auger on a 1/2" Dewalt drill, we've been using, would be too much to hold onto.
Sometimes the bulb auger is tough to hold.
GeoBruin
Just another suggestion, a stud/joist drill that has a long handle, or is configured as a right angle with a long body would give you lots of purchase, lots of power, variable speeds, and they are much easier to find second hand than a dedicated auger. I recently bought one for use with a horizontal boring/auger tool and those were my observations. You would just need an auger bit to fit in the chuck or some kind of adapter.
Here's a (very) short video of it in use. This was my first/pilot bore. I did two more runs under the driveway, one at an angle that was about 18 feet in total length and the dewalt drill was a beast. There was no stopping it.
engineer2
Chicago burbs
Makita has them in both their 18V and 40V platforms, with 4," 6" or 8" augers available. They are reversible. $789-ish for the tool only. :unsure:
Another consideration is renting a gas powered one from Home Depot
J
jrsavoie
North east Illinois
Renting isn't a good option.
I have very random times when I am physically able to do things.
Also we are a minimum 50 mile round trip to the rental places.
We don't want a casserole, because it won't be used much.
Mostly for planting little trees and sticking pots in a garden.
The Makita sounds like what we're looking for. But way out of our price range for no more than we will use it.
signcrafter
I've got a 3 pack of bulb augers for use in a drill, don't remember the sizes but the big one is 3 or 4" in diameter. I used them in my M18 mixing drill made for mixing drywall compound and thinset like products and it works good. I also have a gas powered auger for bigger holes but wouldn't want to use that for bulbs. I have an m18 hole hawg that has a 9/16" hex quick lock on it for drill bits. I have been wanting to make up some sort of adapter to be able to use that with bits that don't have the 9/16" hex shank. I searched one time and didn't see anything like that available. Kind of wish I would have gone with the chucked version of the hole hawg instead of the quick lock so I could use it for things like bulb auger bits that aren't 9/16" hex but it's nice for electrical and plumbing work and switching those bits easily.
knobby
down by the river under a Jeep
The auger makes a huge difference on the effort required to control the drill.
My slight female partner did not have much difficulty with using a 5" auger to plant small trees even with roots present.
Side handle on the drill tho.
Power planter was the brand recommended by the local forestry crew.
