Cordless drill sanding bit?
M-EGT
PHX
Hey all. I bought a bumper at a junkyard and I'm looking to sand it down, and then paint it. I figure I can save time using a bit for a cordless drill to sand it? Any recommendations?
cheechi
Triad, NC
I use mine mostly in my drill press, not so much on the cordless. If you have a hammer drill or one big enough to give you a side handle, then maybe but I imagine it would be pretty awkward. That's how the wire wheel is, you can control it but you have to fight it some.
Mine either came from HF or northern, some el cheapo but it works. I mention it because mine specifically came with only very coarse sand paper rolls.
retrobuilder
Alpharetta GA
It is Very easy to gouge a plastic bumper (cover) with a sanding disk. Is the bumper plated steel? You may be better off using a hand sanding block or try a friends DA electric sander with 120-180 grit. No need to remove all the paint--it's your best primer :)
M
M-EGT
PHX
Nah, its plastic.
And think so? Are you saying I should just spray the color over the existing paint, or primer over the existing paint? thanks
retrobuilder
Alpharetta GA
Unless it is damaged- just hand or DA wet sand with 320 wet/dry paper.
An automotive epoxy primer sealer is sprayed next or apply a SEM aerosol primer sealer.
Then Wet sand with 600 wet/dry with a sanding pad to smooth for top coat.
Unless you are applying paint with flex additive- let a body shop paint it. Otherwise it can easily crack when bumped.
TwoInch
NW INDIANA
do not use a spinning, round sanding drum or disk on a drill, in an attempt to sand a plastic bumper. you will not have an acceptable surface after trying it.
if you are broke, hand sanding something that size wont be a big deal.
also, take retrosbuilders advice too, plastic bumpers dont take well to regular paint.
devinakbv
Thanks. I just have a cordless drill.
retrobuilder
Alpharetta GA
Forget the silly drill..Buy a small pack of 320/400 automotive sandpaper. fold it in half 3 x and wet sand with water from a hose.. you will have better results than a drill sanding pad.. :)
M
M-EGT
PHX
OK, I'll do that. I was hoping a sanding drill bit would save time, but if the results won't be very good then I won't.
And I'm ordering paint online so it will be matched to my car.
M17715
Executive Drive
2nd this. I wouldn't use a circular sander on it. The paint will come off pretty easily by hand. I'd use the fine grit that they mentioned, too. :thumbup:
