Cordless Pole Saws, Li Ion - Any recommendations?
Davefr
OR
Guys,
Does anyone have a recommendation on a pole saw based on Li Ion battery technology?
I'm looking for max. reach but don't need a lot of chain saw bar length.
What's your favorite?
Fbmoose48
GJ
Ryobi has an X-PandIt one for their cordless trimmer. Not pro-duty, but ok-ish
Monte
Germany
e.g.
HUSQVARNA 536LiPT5
Stihl HTA 85
mp_tx
Austin
I don’t promote Harbor Freight much, but their Lynx Li Ion pole saw is an awesome product. $139 on sale. Once charged, it cut non stop for 4 hours. Never bogged down and cut anything I tried.
ptgarcia
Alta Loma, CA
I need one of these, too. Can anyone comment on the Ryobi 18v One+ saw? I can't afford Stihl or Husky and prefer not to add another brand of cordless tool. Does Milwaukee make a pole saw?
Sent from my SM-N910T using Tapatalk
D
Davefr
OR
I couldn't find any mention of a Milwaukee pole saw.
I settled on the 40V Kobalt KPS 80-07 for $170. It looks pretty similar to the Ryobi. The major difference is the Kobalt comes with a 40V 2.5 amp hour battery. The angled head on both of these saws is a nice feature.
The Ryobi uses a 18V 1.3 amp hour battery. However it costs about $140.
If I had a bunch of Ryobi batteries to keep swapping I would have probably gone Ryobi but I don't.
I used the Kobalt this afternoon and it performed just fine and reviews are pretty good.
The Husky with the remote backpack battery would have been a sweet unit but not for $1000!!
Trock03
West of Houston
Ego has a pole saw and extension bar for their power head. I've bought into their line pretty heavily and have had good results for several years now.
IMO their lithium battery technology puts them way out in front of anyone else.
TC
mdurbanc
I would avoid the Ryobi One+ 18V saw. It is the one tool in the lineup that I am not happy with. The chain does not stay tensioned, and continuous tightening of the bar adjustment results in stripped threads I have not yet figured out how to repair.
Marty
ptgarcia
Alta Loma, CA
Marty
Thanks Marty, I'll skip on the Ryobi.
Rarified27
Between PA and NJ
How much cutting do you actually have to do? You'd be surprised how fast manual pole saws can cut, and the reach is definitely there.
Beat me to it- I have a manual one I thought would be garbage until I used it. There won't be nearly enough overhead cutting for me to worry about a powered one.
kctyphoon
Jersey/Staten Island
Yea - real pole saws are EXTREMELY aggressive. Most only cut on the down stroke so they need to be.. I use a hand held one over a chainsaw sometimes for medium sized branches the loppers won't do when I work up in the bucket. I have Jameson ones at work - but I'd bet the Fiskars are just as good. I've done branches 20' up from the ground..
DFB
Southern VT/Western Mass
We have the Oregon one at the Orchard I've used it extensively. Cuts fine but its it doesn't take much side pressure to break the mounting plate. Between the webbing in the casting and all the mounting holes drilled in it it's an inherently weak design IMO. And the kicker is they don't sell that part separately it comes as part of whole powerhead assembly.
They must know about it too because when I contacted CS about it the sent me a new powerhead NC
Ya really need to make short cuts and under cut :D
Trey T
Houston, TX
You're the man. Are you a tree trimmer or aborist? Damn residential tree trimmers around here does crazy tree trimming around here, making my trees look ugly as sin.
thedannyc
Been really pleased with my Ryobi pole saw cordless. I picked mine up at the local swap meet for around $50 with a small battery. I use the large battery when cutting Mesquite. I have never had a problem with the chain staying tight. I like that you can run it with one extension bar or two to adjust the length.
soloz2
Western NY
I know this is a little late, but I just picked up a stihl ht 103 and it cuts like butter.
Sent from my ONEPLUS A5000 using Tapatalk
strutaeng
Dallas, TX
Marty
I second this on the Ryobi. It *****!
Is corded an option? Years ago I used the Remington pole saw. What I liked about it is that it can also be used as a handheld. I really abused the **** out of it for cutting big trees until it broke. The bearing that holds the motor in the case melted, probably from abuse. For tree pruning I'm sure it would last a very long time.
I debated getting another one of the same, but could not find one locally, so I got the Ryobi. I thought cordless would be good. I should have bought another Remington.
The Ryobi does not have telescopic adjustable pole length, just a segment of pole to add, which is not too useful. Even with a big 5 Ah battery, run time is limited to just a few limbs, but the worst part is that it just doesn't compare to electric on power.
gungatim
west mich
funny this came up, I have been looking for one for a couple weeks and all I could find locally were pretty cheap looking and expensive. the battery ones just didn't seem like they would handle more than small branches and most were not long enough.
ended up buying a 45cc gas model with 3 sections 12' reach on Amazon for $209.99 delivered. it just showed up yesterday but haven't tried it yet. reviews were all pretty good.
I know you wanted electric but just in case, it's worth a look...
https://www.amazon.com/gp/product/B00EY5NB3U/?tag=atomicindus08-20
Doug h.
Guys,
I have the Kobalt kps89-07 40v pole saw. It worked awesome until a branch fell on it and broke the motor housing. Of course, no replacement parts available. Lowe's now sells what looks like the same saw with a 10" saw bar. If so, I will have to get one.
