Cordless ratchet recommendations
GirchyGirchy
Central Indiana
If dewalt makes one that uses the same batteries as your impact, buy that. I have loads of Milwaukee tools and batteries so I use its ratchet. I don’t like having multiple battery platforms unless there is no other good choice for a tool.
DeWalt's batteries are too damn bulky for a ratchet. One of the selling points for my older Milwaukee M12's was that the entire thing - head, body, battery - is somewhat compact.
The 3/8" paid for it and its 1/4" brother when I was able to slide it through the frame rail in my truck to loosen (and later tighten) the clamps holding the brake and fuel lines. That saved me from having to raise the bed or drop the tank while replacing the brake line. No way would the porky DeWalt had slid in there...a pneumatic probably would have, but the hose would have been in the way.
I use DeWalt for my main cordless tools, but Milwaukee for anything smaller, such as the ratchets, screwdriver, and rotary tool. I find having the smaller batteries outweighs the negative of dealing with multiple systems.
engineer2
Chicago burbs
Anyone used a makita 3/8? I see it's one of the 'free tool' options when you buy the 5.0 batteries
I have one I got for free with the saw kit. I like the 1/4 - 3/8 interchangeability, but I'm sure the the adapter will get lost someday. It's 40 ft-lbs and not very fast. Was handy working on my snowblower chute and some car motor mount work, but it's a bit bulky for some underhood work. I still prefer my Mac air ratchet for compactness and will use my Makita 18V impact driver when there is room. This is Makita's first attempt (I think) and I'm sure they will soon have 5 different models with varying levels of features and 10 different part numbers for the global market.
anndel
Hawaii, USA
I have a 3/8 in Milwaukee M12, a 1/2 in Milwaukee M12, A Snap-on Long reach and a DeWalt 12V. I prefer the Milwaukees due to their size and then Snap-on for the long reach. The DeWalt is useful with its higher torque but is a bit bulky.
housewolf
East Texas
I’m going to a Dewalt/Milwaukee tool show Wednesday. If I can’t strike a deal on a M12 ratchet, underhood light & a few batteries (I don’t have any M12… I’ll just bite the bullet and go 14.4 V SO for the ratchet & light.
Jeff95TA
Pittsburgh, PA
In case you haven't seen it:
Skyman
Central Maryland
I can't help wondering now long it will be until one of the manufacturers develops one with a telescoping head shaft. I'd buy that.
Steve
WWheeler
Middleofnowhere USA
I was loaned an extended length Dewalt 3/8 ratchet. I was kind of disappointed by its lack of power.
Sounds like you probably want an impacting cordless ratchet. That's an entirely different animal.
I have a mix of Milwaukee and Dewalt cordless ratchets and the Dewalts are significantly stronger although they don't snap your wrist quite as hard when they hit. I tend to favor the Milwaukee small head cordless for smaller stuff and the Dewalts for larger. If it doesn't need to be torqued to 50ftlbs or more I don't usually use the Dewalt. I like to be able to manually break stuff free and finish tightening with a cordless ratchet by hand and only use the trigger to spin fasteners off and on.
AFAIK the Dewalts still hold the title as the strongest cordless ratchets so far in ongoing testing @ Torque Test Channel which agrees with my observations so far.
TBH I don't find the difference in size between the Dewalt 12V and Milwaukeee 12v to be a factor at all. They are almost the same size. They are a lot smaller than their 20V cousins.
1.5ah Milwaukee M12 shown with a Dewalt 2ah 12V, a 3ah 20V, a 6ah 20V, and a 9ah 60V battery.
And though it seems a bit counterintuitive I find I'm very often able to snake the extended reach ratchet into the tightest places where the shorter ones won't go. Enough so I typically grab the longest ratchet first. It's kind of the opposite situation to a hand ratchet where being shorter helps you in tight places. With a cordless you don't need the room to ratchet back and forth you just need it to be long enough to reach it and whatever size the battery end is is not typically a factor at all.
jpmidwest
i love the my Milwaukee 3/8" fuel high speed. im in the autobody trade so i dont need the power that maybe some of you guys need but its quick so its good when you need to take off a bumper or fender. if i needed power i would go with a snap on they are just slow and expensive.
gregs
I recently got the Dewalt DCF503B 12v ratchet and happy with it. I dont find it much bulkier than a typical 3/8 air ratchet once you factor in the air hose connection and the interference the air hose ads. My old air ratchet seems to have more power to break a fastener loose, but they are comparable in speed and tightening torque.
