These are just my own opinions and only because you asked
It a is full 14 inches according to the Amazon site and even slightly longer than the AC Delco which is already longer in comparsion to both Milwaukee's or the Snap ON
Now I haven't ever handled one so can't comment on what the the balance is like with the battery pack on the tool.
But I would tend to think from looking at it because of the extended width and bulk for the battery compared to the more slender profile and shorter overall length of a pod style it (1) that you cant actually use the full length of the tool handle for leverage. And (2) that the battery may be in the way in certain applications. It almost like an M18 RA set up
I suppose one could argue that an using an XC battery could possibly present the same issue BUT the option for a slim battery is still available with them
Even with the bulky FUEL model it is shorter overall and I can grip it all the way back to the end with compact battery inserted.
And if that's one you personally like go for it. Especially if your already on that platform. And the OP asked for suggestions so its an option along with the others presented. Like I said before Makita makes nice tools (I own many)
First, I want to thank you for your well-reasoned and thought-out argument. Seriously, that's the difference between posting and contributing to a conversation.
That said, I disagree with part of your assessment. I think Makita designed their tool with the assumption that people would use the full length of the body to loosen and tighten fasteners. I have a few reasons for this:
1) The tool clamshell has a ton of internal reinforcement and specifically in the battery area it overlaps, greatly increasing rigidity.
2) There is ample surface area to apply force without pressing directly on the battery.
3) There is no warning in the user manual against using the full length of the tool.
I also think the Makita will hold up to pressure on the battery better than Milwaukee, Earthquake, etc. When you put lateral pressure on a stick battery it essentially becomes a lever trying to force the housing apart. It also puts significant strain on the retention mechanism.
Another bonus from not having the battery in the handle is a much more ergonomic grip.
I do agree that the extra length could get in the way in certain situations.
