Cordless ratchet
bixxjs
United Kingdom
Hi All
Can you give me a recommendation for a 3/8 cordless ratchet.The SnapOn guys wants me to remortgage my internal organs for one off the van.
Sticks McGee
Trail Creek, IN
I have the snap on one but I bought mine as just the bare tool as I have many things that use the same battery. The fuel Milwaukee would be my choice if I didn't have this one. It may even be stronger. Have heard nothing but good things about them.
Hammer1963
Kentucky
I had the Snap-on version but sold all my Snap-on cordless tools and switched to Milwaukee. I do not regret that decision at all. I use the 3/8" and 1/4" versions. Great tool and the M12 line extremely versatile. You will be pleased
Bearded_Dragon
Central FL
36ft-lbs seems low. I've never used one but for those who have one, has it replaced your manual ratchet? Seems it wouldn't be used much unless you're on an assembly line, and appears bulky so it couldn't fit into tight areas.
lucky3
The ac delco one is the most powerful I've found. 65ft lbs. I love mine. I paid $125 with two batterys.
xjfish
I own the Snap-On and m12 both in 3/8". Milwaukee is the better value and a good tool. Snappy has a bit more power and was maybe overpriced... I use mine daily, hope it holds up long term.
CGT80
IE, SoCal, USA
3/8ths Milwaukee m12. Run it down with the power and then give it a bit more by hand. They work manually just like an air ratchet. Same goes for removal. Mine is pretty new, and I had only used it in the garage until just the other day, when I had to replace the air/smog pump on my truck. It was nice to have and is much more convenient than my air ratchet.
Sticks McGee
Trail Creek, IN
Here is what I found when using mine. The air ratchet I have (1/4" drive) is rated around the same ft lb of torque. When you put the cordless on a bolt that is tighter than the power of the ratchet it momentarily pushes and then cuts out. When it does this I just use it manually to break it loose until it will run it out. The air one will try to keep pushing it sometimes breaking it free and sometimes I have to use it manually to break it free. When I run things down with it I am surprised at how tight it gets things. Is it a beast that I can throw a bunch of tight stuff at? No. But 99% of the time it does exactly what I need it to do. When you factor in maneuvering a ratchet with and air hose attached MOST times its more convenient with the cordless. I use mine a lot and I am happy to have it in my arsenal.
65 ft lb on a ratchet is pretty beefy. That sounds pretty nice. I have never looked into those.
Bearded_Dragon
Central FL
Cool, thanks for the info!
cre73
Central Illinois
Wow just checked the price of the Milwaukee, would hate to see the price of the snap on. Sure their worth it but dang.
tonyciambrone
Northern Illinois
I have the m12 ratchet... here in Rustopia it does not break much more than a 14 or 15mm bolt free. It's good, just not powerful enough IMO. Plus I really want the direction lever on the body and not the ratchet head.
Maybe Ingersoll? AC Delco? Probably more expensive.
Sticks McGee
Trail Creek, IN
Snap-on 3/8" drive kit (ratchet, battery, charger) is $421. This ratchet is rated at 40 ft lb of torque. IMO that's outrageous on price. years ago I had bought my first 14.4v piece. It was a used screw gun that someone had traded in to buy the new one. It was a cheap deal so I bought it. After about a year I decided that I used it so much I traded it back in to get the new one (the new one was a two speed variable speed with an adjustable clutch and led lights) I can't remember what the price was but it was salty. This is a tool I use pretty much every day at work. A friend of mine at another shop told me the flashlight that works with the same battery was absolutely amazing so I bought one. Just the bare tool as I already had two batteries. I have since added a couple more things in this format. I bought the high speed polisher for home. I hesitated for the longest time on the ratchet but eventually bought the bare tool as I now had 4 batteries for 3 tools and this would make it 4 batteries with 4 tools. The stuff all works great for me and the battery life in this format is one of the best I have had on battery powered stuff. I have a Snap-on guy come once a week and when I get these things I just put it on my truck account with him. I pay him $20/week every week. My balance goes up and down but I never let it get high and I only go thru him at no interest.
My ratchet is 1/4" drive and I can use an adaptor if I use 3/8" drive sockets. The thing is NOT a power house. In many instances I break stuff loose with a manual ratchet and use the battery for running things in and out. If there is room for it I used my Mac battery impact in 3/8" drive for pulling bolts out of stuff. it just depends. I have a Snap-on air ratchet in 1/4" drive. it is pretty small too but I find that it is fairly even in bolt breaking loose power as the battery one. I don't use either of them very much. if I was working in a situation where I was doing a lot of higher torque required stuff where I needed fast and power I would most likely get an air 3/8" ratchet that had some serious beef on power but I am not in that position right now.
So for me the entire 14.4 platform from Snap-on works but if someone was going to just buy the ratchet kit I would say it's over priced and not really any better than the other choices listed here.
Another example of outrageous? 17 pc 3/8" metric starter kit. Deep sockets from 8mm to 19mm in deep. Two extensions, a spark plug socket and a universal joint (chrome one, that I would NEVER use) and a little bit longer version ratchet. $570.00 IMO that is just crazy stupid.
WildwoodChuck
Peru Indiana
I ordered the Milwaukee one for my work for the sole purpose of running button head 3/8"-16 T45 security screws into J clips in a low clearance situation, it works great for that. We are considering the MAC that uses DeWalt batteries for our road box but only because we don't want a 5th type of battery system, we already have DeWalt 12, 20, 60v and Metabo 18v.
