Corless grinder
OccupantRJ
Eastern North Carolina
I have the Dewalt cordless cutter/grinder, and it is the shitz! In fact I love all my Dewalt 18 volt tools. Another possible method is an inverter attached to your vehicle to provide 120 volts to a corded grinder, if you are allowed to bring your car near the site.
A review
OccupantRJ
I can not drive into the yard or I would just use a generator.
The reason I mentioned the inverter is because after it is installed it can be used for a lot of various things. We used them on field service trucks for work on farm equipment back in the 70's, before all the battery tools were around.
rsanter
visalia ca
I always used a cut saw to remove qtr pannels
once its off the grinder is good for trimming and seperating
they have those 'jumper' battery packs that also have a 110v outlet on them
you can carry that in so you can used 'corded' tools that you already have
for cordless tools...dewalt
bob
Major Ramifications
River Ridge, Louisiana
bob
I don't know of any jumper pack that would allow you to run a grinder.
A gasoline powered air compressor would be great. I'm sure you could rent one. At the U-Pull it yards I frequent, they let you bring in generators.
1320stang
Edmond, OK
I bought a cordless Dewalt recip saw just for this reason (they didn't make grinders then) and not the only powered tool they let you bring into the yard is a drill. :(
scott37300
Wisconsin
I have an 18V dewalt grinder and 4 battery packs. I have used it for taking body panels off at the yard. Works great. I also have a panasonic 15.6V cordless circular saw for cutting metal. Use it for steel stud work. I have also used this for body panels and it works good but not as nice as the grinder. I got my grinder in a dewalt kit I bought a couple years ago on sale at home depot, think I paid around 400 for a drill, impact driver, circ saw, grinder, flash light and 2 batteries. Then I got another impact kit with two extra batteries for 120 at the depot on clearance. I only bought this for the batteries since 2 dewalts are the same price as the kit, so basically got a free impact.
The grinder has lots of power and will get the job done easy. And the cuts usually leave the body panel in much nicer condition than a sawzall
djb2
Redwood forests
Many yards have restrictions on what you can bring in. It's rare to allow gasoline powered things. And batteries are often banned, but not battery powered tools.
I cut the entire rear off of a BMW e30, through the quarter panels and trunk floor, using a battery recip saw with a variable pitch metal blade. It was a cheap Coleman saw which went through battery packs quickly. I had four batteries and an inverter back at my car. I estimate that it took six packs worth of charge to do the job.
It could have been half that with a manual hacksaw to solve some of the geometry problems -- you can't always cut where you prefer because of clearances.
Advice: never, ever take off your leather gloves when doing this. Those freshly cut edges are nasty.
H
Heathens
Central Ohio
Thanks for the replies guys, I may just buy a aftermarket quarter, everything around here is so crusty its not worth it.
