correct capacitor for 110v 3.5 hp motor: need help
Jvvmusme
Bogota, Colombia
i need to calculate the correct capacitors (run and start) for a compressor that has a motor of 3.5 hp at 110v. i need also the electronic centrifugal switch
thanks in advance
J
Jvvmusme
Bogota, Colombia
Gonna need more info
What is the brand and model#?
Isthere existing caps?
Type: ML 901-2
Kw: 2.5
H.P. : 3.5
V: 120
A: 27
Ins.CL: F
IP: 55
Hz: 60
S: SI
R/min: 3480
80 MF 250v
600 MF 150v
Able Electric Co.
J
Jvvmusme
Bogota, Colombia
J
Jvvmusme
Bogota, Colombia
Photo of capacitirs
QUOTE=Jvvmusme;7324002]Type: ML 901-2
Kw: 2.5
H.P. : 3.5
V: 120
A: 27
Ins.CL: F
IP: 55
Hz: 60
S: SI
R/min: 3480
80 MF 250v
600 MF 150v
Able Electric Co.[/QUOTE]
J
Jvvmusme
Bogota, Colombia
Hz: 60
S: SI
R/min: 3480
80 MF 250v
600 MF 150v
those are the ones I have and the motor will not start properly.
it worked fine the first time I connected to the wall. after I disconnected the motor and tried it again the motor will not work anymore. every time it will trickle the breaker or show a message of motor overload in the screen
breaker of 40 amps, 8 gauge cable.
James-W
Southeastern Wisconsin
I don't understand the problem. The data plate gives the capacitor values. You have the capacitors that tell you the value. If one or both of the capacitors are bad then replace them with the same value capacitors. Why do you need to calculate what they should be?
walta
Dutzow Missouri
Please measure the supply voltage when the motor is off and again when the motor is trying to start.
The motor is labeled for 120V your post say you are supplying 110V if this is the case you may need a buck boost transformer to get the correct voltage.
Walta
walta
Dutzow Missouri
I do not read Chinese but you may have the wrong centrifugal switch as yours is labeled 220V this photo shows 120V model.
Walta
DenisG
Milwaukee
From other thread:
https://www.garagejournal.com/forum/showthread.php?t=383497&showall=1
jyxg 03-08
from jycapacitors.com
3hp
110v
60 hz
1 phase
116 psi (8 bar)
12 cfm
150 liter tank
electronic control unit
i had a buying agent visit the factory, research its reputation, send me an owners and operation manual . the operation and owners manual has no typing or spelling mistakes !!!! in perfect english .... no chinoenglish....
they agreed on 110 volts,1 phase
$ 700 dlls fob shangai. I ordered 12 units for a 12 friends buying group. I should have them in Colombia by june 15. I will report when received....
Hard to believe that a perfectly written manual from a reputable company would not have included requirements for installation and installation instructions.
This is not a good advertisement for this product.
Worsedog
Central FL
Walta
you know where I can get these in the USA ?
thanks
That is not a centrifugal switch. It is a motor brake rectifier.
While it is certainly possible that you have defective parts in your new compressor, firing the parts cannon is not helping here.
Go back to basics and verify that you have the proper supply voltage and enough current to start the motor. If your supply voltage was too low earlier when you ran the compressor damage could have been done that is causing the problems you are experiencing now.
American Locomotive
Rhode Island
It is a "centrifugal switch". Some websites poorly translate it as "motor brake rectifier". I've noticed that more and more Asian-made electrics motors are doing away with mechanical centrifugal switches. They now often utilize electronic "centrifugal" switches. It just monitors the motor's speed electronically, and then switches out the start winding once it hits a certain speed.
If he's got a 230v rated switch, he will certainly need the 120v one.
J
Jvvmusme
Bogota, Colombia
Problem solved.
An empirical compressor guy arrived with like 20 capacitors and started playing around until he got the right combination.
it tok him like 4 hurs.
40 amps breaker and 8 gauge cable
J
Jvvmusme
Bogota, Colombia
first of all its my fault. I should never had ordered 3.5 hp motors with 110 volts. They should had being 220v 1 phase as the factory had them . So my stuborness in ordering 110v is my fault.
I finally changed the starting capacitor from 600mF 150 vac to the new one of 300mF 250 vac and everything works perfect on all 12 compressors.
