mattdwelder
you never put a vapor barrier in the ceiling
drywalls not happenin
OP: consider 2x4 or 1x4 furring strips at 24" o.c. (furring running perpendicular to 4' trusses. For added strength, consider "blocking" all perimeter OSB joints. For even more strength, stagger your joints. Use 6" ring-shank nails on the perimeter and 12" in the field. There's information on the internet on these diagrams.
The weight of a wood panel is slightly less than the weight of a gypsum board per unit thickness, so I don't think weight is a problem.
There's a lot of hate by some folks for hanging wood panels in a garage/pole barn.
I did a bedroom with 15/32 plywood walls and ceilings before hanging gyp. board and I'm really happy the way it turned out. Properly detailed, wood panels have higher shear strength than gyp. board. Another advantage is that one can walk on the top of the plywood or OSB.
PM me if you have any questions.
Good Luck!
Where in the world are you getting 12" nails from???? the truss is only so thick lol
That is the nailing pattern.
6" On center (OC) on the sheet's edges, 12" OC in the "field".
Im gonna run the 2' center 2x4's perpindicular to the truss spans.The ends will be blocked out off the header and the garage door and back wall sides.. Where in the world are you getting 12" nails from???? the truss is only so thick lol
Staggered How? Why?
Along their length (8') they are all the same. The joint all the shorter side (4') are staggered. Although the ceiling is (atleast mine) is more cosmetic than structural, I wanted to make it as strong as possible. Staggering the joints allows sheathing to bridge more trusses. Each consecutive row will tie into another truss or two stiffening up the structure.
The same thing is done on roofs and floors when sheathing is put down.
I have no idea why I thought putting the nailers up was a good idea... I can just fasten the osb to the truss... ends and center
i plan to paint the OSB
i just ran to stoneburners and priced metal sheets It gonna run me roughly $875 for the metal with no hardware 1.97 a linear foot. Cut to whatever length SO I just did an est for 3x12.
OSB ceiling is gonna be $418 plus a couple gallons of paint and hardware..
My shop is 30x40
My pole barn is on 4 ft centers. I would have to rip sheets to use the trusses to nail to wouldnt I?
Well upon further review where my truss's came from..... The truss load rating cant support osb plus the 2x4 bracing and be able for a snow load it would be questionable. And i dont want any issues with insurance saying I overloaded the truss if anything were to ever happen.....
Im gonna have to purchase the metal and use funds delgated to other not so essential things..... Just when I thought I had everything figured out....
Always a lot of chatter on this topic. Thought I would let my pictures and results speak for them selves. Don't overanalyze it. It's not rocket science.
I don't put it anywhere. It will rot the place out.![]()
Why would a barrier of 6 ml plastic under the trusses cause rot?
