Corrugated metal walls for bathroom
CHELSEA02
I have seen beautiful pictures of garages, and I want to do this as a wainscoting for my bathroom. One question though, I have 16" studs and sheets are 24" wide. Therefore, where the metal overlaps will not always fall on a stud. I am attaching these on a drywall. Will screwing the two sheets together directly to the drywall work to keep them from being loose at edges?
Theo911
you could attach some thin furring strips horizontally along the wall then attach the corrugated metal to those.
Howling
IL
Corrugated metal furring strips.
https://www.homedepot.com/p/Palruf-...gclsrc=aw.ds&dclid=CPz0k86ct9gCFQwpPwodpg8HFw
Sent from my SM-G955U using Tapatalk
rburke65
Canfield, Ohio
You could pop rivet the sheets together and then just screw to the studs. Two sheets...48" and you'd hit three studs.
crguy
SW Washington
OR, you could come to your senses and forget the whole stupid idea. As far as I'm concerned, corrugated metal doesn't belong anywhere inside a building. It's just another one of those "trends" that will be laughed at in the future.
AMCguy
Sunshine Coast, BC Canada
I don't have any mounting wisdom to offer, but there's a restaurant nearby with corrugated galvanized metal in the washrooms and it looks like hell where over time, wash water and pee has been allowed to come into contact with it.
Bronson
Texas panhandle
You can just stitch the laps with short self-tappers, it doesn't have to penetrate the backing.
Maybe predrill the holes since there will be no structure to back it up.
Bronson
Texas panhandle
Agree.:thumbup:
Automobilist
Snohomish County, WA
Exactly... Like the lame "rat rod" fad of flat paint, red wheels & whitewalls. That trend is so unimaginative... :evil::evil:
Go ahead and install the metal right over the drywall. Simply use the sheet metal screws typically provided, and shoot a couple along the overlapping seam. It's not structural, so getting into the studs isn't too big of a deal.
When / if you change your mind down the road, and want to redecorate, just unscrew it, patch the screw holes and finish it however you like.
supersaiyan93
North Georgia
Agreed. We put some in my son's room and used that method. I just simply screwed it right into the sheetrock. It's held up fine for almost 5 years now.
LS6 Tommy
Northern NJ
First thing that came to my mind. Even if you don't splatter when you go, the corrugated WILL corrode. Take it from someone who has seen a LOT of public school and commercial building restrooms with zink/galvanized/ferrous metals used in the wrong applications...
Tommy
kbs2244
If, after all the warnings, you still want to do it, horizonal furring strips is the way to go.
You will need to remember the extra thickness when you get to the top rail.
NUTTSGT
Northern Central Ohio
This is exactly what I would do.
I'm guessing this is a home bathroom ? Like Tommy mentioned, watch the aggressive cleaners.
Rc_Guy
Minnesota
There is always a few in every crowd.
