Costco "garage deal"?
om-nc
north alabama
Anybody else notice the "Garage in a box" deal at Costco?
Here is the link: http://www.costco.com/Browse/Produc...860*28174*&whse=BC&topnav=&Browse=&lang=en-US
Deal includes 7.5, single phase, 80 gal IR compressor, and a bunch of tools. I haven't priced them all out but it seems like a good deal.
Costco price, delivered to your door #3,999.00
Thoughts?
Here is the list for those that don't want to link away:
Air Compressor:
Two-stage - Type-30 compressor
Durable 100% cast-iron construction
100% continuous-duty cycle which extends pump life for years of trouble free service
24 CFM at 175 PSI
7.5 HP
230 Volts (Single Phase)
80 gallon vertical tank
3/4" air NPT outlet
Dimensions: 26" L x 38" W x 70" H
500 lbs.
Made in U.S.A.
1/2" Titanium Impact Wrench:
Ergonomically designed
700 max ft-lbs. of torque
1/4" air inlet NPTF
9500 free speed RPM
3.95 lbs.
7.34" long
1/2" Ratchet:
New head design
60 max ft-lbs. of torque
275 free speed RPM
2.75 lbs.
10.7" long
3/8" Drill:
400 free speed RPM
Variable speed throttle
Lightweight and compact - 3.3 lbs.
Sander Kit:
Two-Tool Kit
Air random orbital sander(vacuum ready)
Die grinder
3" Die grinder backer pad (1 )
6" Die grinder backer pad (1)
3" Prep disc (8)
6" Hook & Loop (6)
Grinder Kit:
Blow molded plastic case
Grinder
.33 HP motor
8 Grinding bits
92 sound dBA
25,000 free speed RPM
1.27 lbs.
6.75" long
Positive grip
Installation Kit:
6 ft. 1/2" hose to connect compressor to hose reel
3/4" to 1/2" NPT bushing
1/2" NPT close ******
1/4" NPT air coupler
1/4" NPT connector plugs (6)
Anchor bolts (4)
Teflon tape
Socket Set includes: One 1/2" drive SAE impact socket set with 13 pieces and a metal tray. Sizes: 7/16", 1/2", 9/16", 5/8", 11/16", 7/8", 13'/16", 15/16", 1 1/16", 3/4", 1", 1 1/8", and 1 1/4"
Start-Up Kit:
All-Season select lubricant
Two year extended pump warranty
Replacement filter elements
50' Hose and Reel:
Easy roll up hose storage
Long reach for air tool useage
Air Filter/Regulator:
Air filter/regulator combination complete with gauge
Adjustable pressure range 5-125 psig
Bowl size – 6 oz.
Bowl type – composite
2.03 lbs.
spencerian
Columbus, Ohio
I put together a similar set at NTW...
1/2” Titanium MAX Air Impactool™ $244.92
Stock Number: IRC-2135TIMAX
Unit Price: $244.92
1/2” Ultra-Duty Air Ratchet Wrench $132.74
Stock Number: IRC-1210
Unit Price: $132.74
13pc. 1/2" Drive SAE Deep Socket Set $48.66
Stock Number: IRC-SK4H13L
Unit Price: $48.66
3/8” Filter/Regulator with Gauge $40.86
Stock Number: AST-2615
Unit Price: $40.86
3/8” Heavy-Duty Air Drill $96.64
Stock Number: IRC-7802A
Unit Price: $96.64
3/8” x 50’ Air Hose Reel $150.87
Stock Number: ATD-8031
Unit Price: $150.87
7.5HP 80-Gallon Vertical Type 30 Series Two-Stage Air Compressor - Standard Package $1,949.99
Stock Number: IRR-2475N7.5
Unit Price: $1,949.99
START KIT 2545E10V $79.32
Stock Number: IRR-32305898
Unit Price: $79.32
Surface Prep Combo Kit $233.58
Stock Number: IRC-4102K
Unit Price: $233.58
Order Subtotal $2,977.58
Even a good set from Snap On...$3,093.55
