Hi, been looking over post and on the web. Thought i would check in here for advice
I have a 24x48 garage that has a wall down the middle with a 12' x 8' opening betwen the two sides (so basically 2 24x24 garages). I am going to either use freezer curtain (clear plastic) or sliding doors) to seperate the two at times, one side is a clean side for my finished car and wifes daily and the other is for building my hotrods (grinding, welding etc...) the walls are 10ft. R13 wall insulation and 2" thick 18x8 insulated garage doors. 1152 overall sq ft, each side is about 575 sq ft.
I want to use electric (getting gas to my garage is not going to be easy). Since I plan to be able to seperate the areas, I think I plan to run two units.
I think I need a two unit that are somewhere between a 5kw and 7.5kw in size. I see most of the 5kw are for up to 500 sq ft (is that pushing their limit?)
I live in the Seattle area so most winter days are in the low 40's and nights in the low 30.. we do get days with temps in the low 30 (teens at night). this winter is expected to be colder then normal so more 30 degree days. I would like to be able to maining a 50-55 temp when I am not in the garage but be able to get the room up into the 60 to 65 range when I am in there.
I believe I will have to run 240 and I have a 200amp panel so no problem powering the units
I would like something quiet and not over taxed to maintain the heat.
what are some good products that is not overly priced (not looking for the cheapest unless that happens to be the best choice) that will meet my needs. I am not familar enough with the different brands to know who to keep away from and how is reliable.
thanks in advance
thanks in advance
