Keyblazer
Love reading and learning here, so here is where I come for advice.
Working on the restoration and customization of an old Airstream Motor home...
Lots to do, but this is about where I am so far...
My issue is the "ugly" grey painted corner fairing panels front and rear between the bumpers and polished sheet metal.
They are ABS vacuum formed panels originally... and mine are brittle and cracked already, so need replacing.
They were NEVER good even from the factory... you can buy new panels... at $500 a corner.
I could, and have the skills to repair them, make them good, take a mold and replicate them in GRP myself.
But somewhere in my mind, I have an itch to make them in aluminum, and polish them out to match the body...
I have a good skill set, but not a ton of metalwork experience. I was a sculptor/pattern maker in a previous life. Wood, clay, plastic, and GRP is in my wheel house.
Have a new TIG welder(Eastwood 200), Plasma Cutter, a 30" combo shear/ slip roll, brake.
Planning to buy other tools like a shrinker/stretcher, bead roller, and English wheel etc.
Have hammer formed some small pieces, and have some metal fab skills.
Here are a couple of closer shots(not my rig, but the same... the grey paint shows the shape better)
Front.
Lower side view of shape.
I want to simplify this shape little... eliminate the recessed amber signals, and maybe even roll the panel behind the bumper to hide the edge.
Ignore the spoiler... I can make that later, and attach as separate part.
My first look leads me to first make a hammer form/eggcrate off the OUTSIDE of the original panel.
A 2 part panel, TIG'd later.
18/20g?
First piece would be cut along Line 2.
Upper part matched to body curve along line 1.
Rear edge profiled to wheel opening curve Line 3.
Line 2 edge would be hammer formed to part of radius
Other part of panel is defined in blue here... almost flat, with edges hammer formed into part radius to match other part.
Matched, and TIG welded together, and finished/polished.
Rear is similar, less complicated, but longer.
Opinion, crit, and advice welcome..
GO!
Front.
18/20g?
GO!
