No one ever taught me how to drill through steel and I never really thought to ask and I struggled a bit tonight. I wanted to drill two 8 mm holes into an old steel trolley jack to add a handle. The steel is about 4 mm thick.
Using an M12 drill with upgraded rohm chuck suggested by reddit. Norseman Magnum Premium Drill bits I got from a Prime Day special a while back.
Started out with a small pilot hole around 1/8"and it took forever. I didnt want to start too small figured a 1/16 might snap. What was weird the 1/8 bit didnt get hot at all. I took breaks every 10 to 20 seconds because I didnt want to damage the drill or battery. I used spray lube I had as a cutting oil. It took me about 15 minutes to drill this first hole taking breaks.
I used bigger and bigger drill bits I jumped up 2 to 3 sizes at a time and it was working pretty good. Only took about 10 seconds each time for each next drill bit. I tried to jump more at first but was struggling.
Once I got to around 1/4" I had to go to every size and it started getting much harder. The drill bit would bind. And whats weird is the drill bit would start smoking and getting burning hot after only 3 seconds and need a couple minutes to cool. I didnt want to risk snapping any and wasnt in a rush so I just waited each time. Each hole at these sizes took about 4 times of 3 seconds each to clear them with 2 minute break between to cool the bit.
Eventually got to 5/16" which was the closest to the M8 bolt and used a tiny round file to deburr it.
If I knew what I was doing or maybe these arent good drill bits for this job then this single 8 mm hole wouldnt have taken me 45 minutes. Going to do the second hole tomorrow. Got the blue painters tape on there marking the second hole.
In the past I used to dip drill bits in a cup of water every few seconds but looking back that might be dumb with heat shock to the bit. I did find tap cutting oil in the garage I could use tomorrow.
What can I do better? Other than taking it to someones garage with a drill press
