Counter-tops for garage?
ladrones
NM
So I'm trying to get around to organizing and setting up work areas in my garage. I was given some old cabinets that I think I can put to use in my garage. The cabinets are solid and I can easily attach them to the wall. They could use some paint and hardware.
I was thinking about milling up some oak 2x4's up and using them as for the counter-tops. The cabinets are 81 inches long and 24 inches wide. The finished counter-top would be 4 inches thick. Maybe some pegboard to hang the most utilized tool above the cabinets?
Any other ideas for counter-tops?
I will move that fire cabinet and build a desk area in between the cabinets. That is just an idea in my mind anyway.
A couple of photos to give an idea of what I'm working with.
akdiesel
Wasilla, AK
That sounds like a great idea. Some members here have a great job on their counter tops doing just as you want to do. Some have even aged it for a more rustic look.
kbs2244
I am assuming those are upper cabinets?
If so, put them up on 2x4 spacers to get some “toe kick” room.
Then go to the local Habitat for Humanity and get some light colored Formica type tops.
Cut them to the depth you need on a table saw (apx 30 inches) and you are ready to go.
superdutymike27
SE Wisconsin
I was fortunately able to nab a 14 foot countertop (laminate) a few years ago to make one continuous top for working. It's smooth, flat and cleans up well. I was also fortunate to grab a relatives base cabinets they were throwing away. It's a nice set up along 2/3rds of my wall. It also matches the garage decor. Almost like I planned it. A lot of the big box stores have left overs and different colors sizes for pretty inexpensive.
My 2 cents!
Adam McLaughlin
Santa Rosa, CA
I'd cover mine in steel
I work on transmissions all night and all weekend; wood wouldn't last a day with my stuff. Soaking in AFT, beat down from bushing driving, etc. etc. etc.
Adam
dandan111
Indiana
4 inches think would be a little over kill but if you have the lumber go for it. Maybe you can rip them so its 2 inches thick?
justanengineer
Motor City
I say go for it, but consider going a bit deeper. I like 30-36" deep myself for bench tops. Oak "butcher block" style tops will likely outlive you and at 4", a power hand plane will make quick work of refinishing them in a decade or two. If you plan to do a lot of internal engine, trans, or other work with precision components, a non-steel bench should be considered a requirement.
Falcon67
Merkel, TX
It looks like your all set for concrete counter tops. That would be cool no?
Not really in a garage. First whack with a hammer and chips are flying off. If a heavy piece cuts through the polish and seal, then you start getting grit in everything. Plywood with a replaceable hardboard top, or maybe steel gets my vote.
L
ladrones
NM
I can mill anyway I need to. I'm Thinking about just doing to slabs 24" wide 3" thick for the length of the cabinet. That would be the easiest for me.
Reborn996
What about Corian? It is a solid surface and should hold up well for at least light/medium duty work. Also, how about Bamboo? That is the upgrade surface offered with the Ulti-Mate cabinets I plan to buy.
David
L
ladrones
NM
I got a chance to mill some pieces today.
http://sphotos-a.**.fbcdn.net/hphotos-ash3/644538_4656452094623_2113263791_n.jpg
http://sphotos-b.**.fbcdn.net/hphotos-ash4/313717_4657584762939_1758028972_n.jpg
NUTTSGT
Northern Central Ohio
Make sure to post up more pics of that as it progresses.
I have a small bench that has a laminate top on it. It was my first bench as a teenager. I find it works great as a paint bench, I open/mix/pour all my paint on it, makes for easy clean up.
wrench409
Over here....
Another good source for durable workbench tops is reclaimed flooring from old rail cars. After milling they look great.
machine_punk
Napa Valley, California
OOOH...THAT kind of mill. Which is VERY cool. I would be concerned about that big a chunk of wood splitting, as it dried.
I like double-thick 3/4" plywood tops...you can stagger the layers to get as long a top as you need.
Kev
Nostraquedeo
I have had a stained concrete counter top in my garage for about three years now with no issues. I don't do anything ******** on it though. It's more of a work surface for small things. 3" thick with black die, looks really good. For the ******** stuff, I have some stained large wire spools that I can move around the shop. They are about 36" diameter and about 36" tall. Perfect mobile work benches and saw horses. Oh, and the concrete counter top cost be about $50 including the die. It's aprrox. 30" deep and 10' long
L
ladrones
NM
We milled 4 pieces yesterday. I unloaded in my shop today.
I like this split piece.
10' long 3 inches thick. Re-claimed from forest fire. It does not have a great deal of moisture in it any more. I also milled up some 2x12x14 and 4x4x14 to make a base for a solid core door reloading table I want to finish.
