Ryf
I have a hodge podge workbench made of wood, I do a fair bit of metal work, but I have alot of lumber around as well.. I will have my new shop built in 2-3 weeks, this puts a new problem at hand. I want to have a sturdy workbench to pull on, I am not sure I want to put holes in the concrete to be permanent too soon (and dont want to tie into building structure as its a enclosed carort design)
so I am thinking a workbench base of lumber, along the bottom two runners of heavy angle stacking a row of cinder blocks on edge along said runners. a cap block weighs between 22-35 lbs according to lowes, and a 6 ft bench (5.5 inside) maybe with blocks on edge is 16 blocks at 22 lbs is 350lbs... thoughts? I see that as about $40 worth of 350lbs weight which with mechanical advantage through its length and leverage, I should be unable to move it without some real effort since I am 6'2" 300lbs.
anyone got thoughts or a better idea, I am looking what I have and trying to make it work, as budget is a factor.
