vintagefan
- Joined
- Mar 2, 2012
- Messages
- 613
I just picked up the last 60g Husky in my area, the red one they were clearancing.
http://www.homedepot.com/h_d1/N-5yc...0053&langId=-1&keyword=husky+60&storeId=10051
I got it home and installed it to the garage floor with large rubber sandwich mounts, so it is 100% isolated. You can't feel even the tiniest vibration in the concrete. I also installed a much nicer aftermarket pleated filter, and new regulator.
Anyways, when the compressor starts, the motor vibrates about 1/16" or so. As it starts to build pressure though, it gets really bad, like the back of the motor is moving almost 1/4" up and down
I'm really afraid that it's going to eventually crack the motor mounting bracket.
I can't imagine this is normal?? At least, I've never seen a motor move that much on a compressor, and I've been around them daily for 15 years.
Could it be one of the pulleys or even the belt?
Also, the crankcase is building pressure. Not a lot, but enough to hiss and build pressure behind the cap (I leave the cap cracked a bit so it can vent). I'm finding mixed opinions on google as to whether this is bad or normal.
Some say it is the rings, but I don't want to tear apart the head on a brand new compressor pump to find out when it might not even be an issue at all.
Thanks in advance
Thanks in advance
