Good evening. My wife and I recently moved into a new place with a second garage. It has an in-floor radiant heat system in it. I've never had a system like this in my garage, just a regular gas style, which is what's in the main attached garage.
Anyways, since it's getting to that time of year, I decided I might as well try the in-floor heating system out, and make sure it all works properly, instead of 2 months from now, when I really want it. I flipped the main breaker at the panel, then there's also another breaker on the in-floor heat boiler system. There's also a switch for the pump. Everything seemed to activate as it should, I turned the breakers on for the heating system, I could watch the temp gauge rise, so that's a plus, I would consider that one of the most important things in a heating system. Then I flipped the switch for the pump, it worked properly. But I could hear some noise in the system, where there were elbows in the copper pipe before it went to the pex tubing under ground I could hear what I would think is air. I could also see there may have been some leaking maybe a high pressure valve, so maybe it's low on water?? If so, how do you add water, also does it use just regular water, or some sort of anti-freeze?
Also, I would like to add, it's not a gurgling sound, it's a running water sound.
I've added a couple pictures of my setup to hopefully explain myself a little better.
Thanks
Thanks
