First, does anyone else have studs that are 19" on center? If so, how did you insulate? Most insulation widths are 15 or 23 inches.
Second, what R value should I use in the NY area? I have a two car attached garage that I wanted to finish off. I don't need it room temp but I want to be able to heat it up enough to go out there and tinker a little in the winter. I was told R11 would be fine but then some say to go higher. Any suggestions?
THANKS!
THANKS!
