Cove base moulding
bluestripe67
Close enough to Wash. DC
I did a search and found some good tips that I will use, but I still have a couple of questions. Beside the cost difference, what is the advantage, if any, of rubber vs vinyl moulding, and and advantage of 30 pack vs a coil? TIA :beer:
boiler7904
NW IN
Rubber seems to be more flexible and easier to cut.
Rubber base vs Vinyl base
Big advantage of a coil is that you don't have a joint every 4 ft. While it makes install a little more difficult, the end product looks better.
Silver Heels
I have used the kind that comes in a roll with an adhesive back and was not happy at all with it. It did not lay flat, stick well, and expanded/contracted along its length leaving gaps at the end. I have also used the glue on kind that comes in 3.5 ft (or there abouts) lengths. MUCH better product. You have seams but they are almost invisible, it is stable, and stays put. Goes on flatter and just looks better.
mikec35
NC
^^^^ what he said. My guys quit using coiled because it would never lay flat against the wall.
The Cobbler
agree with the 4' lengths laying better . having said that, we do contract flat rate work and the 4' lengths would be too much waste as the dimensions don't really work out. therefor we use the coils. Johnsonite is better quality than some
Cyberbear
California
I guess being old school, I still prefer the ridgid wood stick molding, as I presume you are doing base board molding? Paints good, nails easy, cuts are no problem, etc...
If cost is a factor, MDF molding works good here on the left coast.
fireant911
Alabama
I just did this project last month. I precisely measured every area that would require cove base and arrived at 135' 10" thus I opted for the 120' coil and four 4' pieces. I purchased mine at Lowes (Flexco ThermoPlastcRubber Wall Base 4"X120'X1/8"). I purposely selected an alcove area to install the 4' strips because of the seams. I had no issue with the coil material not standing up straight against the wall. In fact, it went up very well. My longest continuous piece was, as memory serves me, about 40' long with two inside corners. I measured tree times and cut once! I ended up with one seam in the area I used the coil. The alcove area looks good also but three seams are present and I prefer the look of a smooth, non-broken cove base. I applied the adhesive using just a putty knife.
The biggest issue I had was with the Lowes representative in charge of flooring! My wife wanted a different color other than the three colors available at Lowes. Even though Flexco's policy is a single price regardless of color (FlexOne Pricing), Lowes was going to charge nearly double to order the other color ($69 for the in-stock versus $112 for the other color). I purchased two of the in-stock 4' strips in different colors so that see what it would look like. We then opted for one of the in-stock colors. After watching a couple of YouTube videos concerning the installation, I was off and running.
As for the differences in vinyl versus rubber. I seem to remember reading that one material must be allowed to acclimate to the space whereas the other can be installed immediately but I could not locate that information this morning.
bluestripe67
Re: Update on Cove base moulding
Contractor just finished the Polyaspartic floor. For my cove base, I went with the 1"x6"x8' common pine. They will be primed and painted gloss black and sealed to the floor. :thumbup:
James E
Raleigh, NC
In my limited experience, I prefer the coil over the short lengths because the coil minimizes seams. Of course, when I install it myself (non-commercial), I have the luxury of laying out the coiled molding flat for a few days so that it installs flat. I usually throw away the last four of five feet of the coil as it never gets flat.
I rough cut the lengths from the coil before I install them. There will be a couple inches of extra waste at each end but it allows me to lay the pieces out on the floor.
If I were a commercial installer, I obviously wouldn't have that luxury.
I also use the mastic for installation. Self-adhesive pieces always fail over time.
rlitman
Long Island
Put it in a warm place. It gets flat.
