We;re buying a house Dec 30th w/ an attached garage. Aparently the PO has painted the floor w/ a simple cover, not sure what but he said "just a basic latex (?)".
I'd like to put in a good cover before moving in, but don't have much time to do it.
Been doing alot of reading about epoxy vs vinyl interlock tiles vs VCT re: durability etc.
Trouble is, I do alot of automotive work and am hard on a floor, this will definitely be a "working" garage... aside from the usual auto fluids, also having a heavy jack dragged across it, tools or auto parts dropped, heck even big chunks fall sometimes... i also do welding, cutting, grinding...
I'm not real concerned w/ it looking "pretty", mostly concerned w/ easy cleanup - I hate laying on my back on a nasty floor.
I know welding/any hot stuff is bad for any material, I can plan to use blankets/protection and prob have something different under my workshop.
only ~400 sq ft so $$/ft is only a moderate issue.
my thoughts are:
- snap together vinyl tile - easiest install, can go over the existing painted floor - but how does it hold up to this kind of use? Does dragging a 3 ton (say 75 lb) floor jack across it destroy it? what about dropping, say, a 75 lb differential?
- epxoy - more durable (?) but will require removing all the current floor, considerable effort/time for install, probably untenable in Jan? slick when wet?
- VCT - easy (er) install- but can it be put on top of paint? How is durability for this? I liek te hidea of being able to just replace tiles here and there later if needed, cheaply. Does it absord oils? Get slick?
I'm leabing towards VCT but would like to hear input.
my thoughts are:
