My 19x19 interior Garage is a concrete tip up construction, built in 1942. I've considered putting a grid of 1x3 strips and covering with 1/2 inch OSB on the walls. I live in Northern California near the coast with very temperate weather with highs seldom over 100 or below freezing overnight.
Pro's
More finished look
Easier to attach Cabinets to wall
Insulation effect
Con's
3 inch reduction in width effect on square footage
Possibility of transferring existing WAVE in Concrete walls
Questions
Should I put foam board insulation if i'm going to do all this work? B: Then i should insulate Ceiling too?
If I don't heat the garage will I have moisture issues?
in Priority order, Sealing up the main garage door with a good seal should come before this?
Pro's
More finished look
Insulation effect
Con's
Questions
