covering epoxy floor
yard_dawg
west tn.
i have a epoxy floor now, it is coming up in a couple of palces. was wondering , if i go back with same kind and color, what am i looking at in preping the floof to cover the bad areas
Jabberwalk
Knoxville, TN
If the areas are small you could hand sand witrh an 80 grit sandpaper, clean area and then recoat. If you are wanting to put a coat over the entire area you will at the least have to sand the entire surface, or at best have the old coating ground off and start over again.
