I bought a open box coxreel.
The teeth part of the reel doesn't reach over to the pawl.
I tried to push the reel over so the "teeth wheel" would reach the pawl but no luck. How does that happen? I can see the spindle but it won't go over much, need about an inch
the whole thing is broken because the brass swivel pinches the hose as it spins, there is some kind of binding because the threaded inlet also spins.
While it is obviously a defective dud, I have a chance to evaluate the quality. The spacer on the swivel side is a little cheesy it looked like a PVC pipe.
The steel reel and base plate is heavy but the supporting plastic parts are not. The hose it comes with is cheap, it's PVC and like a garden hose. overall, I am a little surprised how badly broken it got after it leaves the factory. I can tell someone used it somehow knocked the reel over an inch that it shifted out of the pawl position, binded the swivel part, and returned it.
I am not sure I will be buying one again?
