Cp 7732 ( mini impact )
joedodge
Tampa, fl
Just got one of these and it is absolutely amazing. Light small and very powerful for its size. Did some spring hanger work on a international no problem. Deffinatly something the pro techs should look into for a time saver. Maybe not a daily use impact but definatly a good one to add to your box.
J
joedodge
Tampa, fl
It's a 1/2 impact. Yeah sorry the milwaukee m12 drill and pocket screwdriver are there for scale lol
dudutzu905
"The new Chicago Pneumatic CP7732 is an ultra-compact and powerful ½’’ metal impact wrench. At only 4.4" long (112 mm), this stubby impact wrench is ideal for very restricted areas, like transmission and engine work. Since this tool is shorter than your hand, anywhere your hand can fit, so can the CP7732!
CP7732 Impact Wrench
Small but also powerful, the CP7732 1/2" stubby impact offers excellent power-to-weight ratio: 450 ft.-lbs.(610 Nm) of torque, but weighing only 2.9 lbs.(1.3 kg). Unique to this tool is the ability to quickly change this tool to be operated by a left or right handed mechanic. Additionally, CP7732 user-friendly features include a one hand operation trigger with 3 position settings in forward and reverse. It is a must have in every mechanics tool box to easily work in tight spaces that are unreachable with a standard ½ impact wrench!"
huh?:headscrat
mtwaterguy
huh?:headscrat
Moving it from one hand to the other?:lol_hitti:
J
joedodge
Tampa, fl
No the way the direction switch is you can swap it side to side for if you are left handed instead of right handed since the direction change is made by the teigger
Ruger_556
I have one, it is awesome for suspension work and frame bolts. Lots of power surprisingly :rocker:
Monte
Germany
another shortie :)
Hazet 9012M
Monte
Germany
<iframe width="640" height="360" src="//www.youtube.com/embed/wDICeANUS0o" frameborder="0" allowfullscreen></iframe>
