Crack Mitigation for Internal Posts
78SC4X4
Port Orchard Wa
I'm preparing for my 4" slab pour and have been following all the tips from @LLWillysfan sticky. I have four 6x8 posts in the middle of the slab to support the mezzanine. From my googling, I've figured I can cut diagonal control joints, place rebar at a diagonal (see attached), or actually install an isolation joint around the post. I understand that rebar or cutting control joints will only minimize the cracks. I'm looking for some informed opinions on the way to go here.
ConCretin
Central Maine
If I understand your question, you're asking which detail you should use at your mezzanine piers; column block-outs as shown top or rebar as shown below.
Either of the two column block-out details will definitely work. These are formed pockets that are filled in with a second concrete placement. Obviously a lot of work and not great aesthetically.
The lower detail showing rebar at a re-entrant corner is a 50/50 proposition at best. It's a very common detail in commercial construction and isn't very effective at preventing cracks. The engineer is basically admitting the slab is going to crack and sticking some rebar in to keep them tight.
As a third option, you could wrap the piers with expansion material to 'soften' the corners and provide for some movement. This might be enough to prevent cracks
You could also cut your control joints perpendicular to the post corners in a pinwheel fashion. This would be a simpler, better looking detail that would give you a reasonable chance of avoiding a random crack.
As a famous man once said, "Re-entrant corners ****". Oh wait....that was me. Well I was right, they do. It is very difficult to prevent cracks when this condition occurs and occasionally they'll show up despite your best efforts. Usually right beside a control joint that was supposed to prevent it. At the end of the day, the best way to control cracks is too avoid them so try to place in moderate temps if possible and pay close attention to slump, curing, etc.
Good luck and congrats!
78SC4X4
Port Orchard Wa
Thank you. That is exactly what I was looking for and confirms what I was thinking. The pinwheel is a new concept to me but looks promising and straightforward. Now if we could just get over the record heat here and get back to "moderate temps"
