Bigrhamr
This is a picture of a basement that a friend of mine had a contractor do. It was poured right before a hard freeze and the footer was not covered which I believe led to frost heave and the cracking. The top cracks widened up to the point that you can clearly see there is no rebar over the window opening. The section over the window has very little holding it in place, I could kick it out. The crack on the lower left of the window goes down to and continues through the footer, it is cracked clear through.
There appears to have been several mistakes made here but the question I would like to ask is what you would do about this? The contractor wants to cut out the upper section of the wall and redo it, then grind out the lower crack and patch it. Is there any way that would be an acceptable fix considering this is a brand new job and not a repair of old work?
