Mikie
I need the following sockets;
STD: 4.5mm & 15mm
DEEP: 4.5mm 5.5mm 15mm & 5/8"
All 1/4" drive. Thanks!
STD: 4.5mm & 15mm
I may have these, I'll check when I get home tonight.
STD: 4.5mm & 15mm
Cman does not make the Deep 4.5 and 5.5mm nor do they make the 15mm.
I see your trying to fill up the hansen trays.
I may have the 4.5mm std and the 5/8 deep I will check when I get home.
I'm beginning to believe to are correct on your first line, you are definitely correct on your second! You guys know your stuff! I'll wait to hear from you all to see if you may have the others. Thanks!
I''m filling my trays out too with missing sizes. CM makes a 5.5 deep 6pt socket. For the 4.5mm's and 15mm's I went with Armstrong and Blue Point for the 5/8's.
Mikie,
Which letter code is on your socket's? I'm sure I have enough of the shallow socket's that I can get a direct match to your set. The deep socket's will be luck of the draw.
Mikie,
6pt or 12pt? I glanced over all the posts and didnt see it mentioned.
I'll write down your list, and dig through my box shortly. I may have something.I got a bunch of loose single Craftsman... Not enough for a complete set, but maybe I can complete someone elses!
