1967 R502
So I’m wrapping up a restoration on a 1949 craftsman 100 drill press. There seems to be quite a bit of run out.
~.006” measured at the spindle taper and ~.02 measured at the bit.
Either of these measurements seem to be too much to me.
1. Are my expectations too high?
2. If this is in fact too much run out how do you adjust for it?
3. Later presses often have an adjuster bolt which will alternately squeeze the head or the quill to adjust for this, but the 100 has no such adjustments.
4. I’ve tried reseating the chuck in several positions, which no change to the overall run out, so I’m pretty sure the chuck and taper are ok. Of course this would not do much for the run out at the spindle.
5. Belts are level from to back and side to side.
6. Quill bearings are new.
7. Pulley bearings are repacked.
Suggestions?
Suggestions?
