Craftsman 103-0303
pjaf
Hello First time posting here . I’m looking for the knob that holds the quill return spring on my Mohawk drill press . I have the spring but the knob is missing. Even if someone has the dimensions I have a friend who is a machinist and MAYBE could make it
Thanks
MAD
Western MA
Thanks
You may want to search/post your question over on the Vintage Machinery site http://vintagemachinery.org/home.aspx
Michael_PE2003
Cleveland, Ohio
Mine is the later 103.0305 but uses the same spring and knob. Mine was also missing the knob and spring. I have seen them on ebay occasionally at around $100. I have a lathe, so I made my own from a piece of aluminum.
The inside cavity is sized to the OD and width of the springs I found, the OD is a bit under the ID of the opening in the head and the head was made by cutting a couple of angles and blending with a file. The grooves were made by using the lathe carriage to make a series of shallow cuts on the edge using a lathe tool on it's side and a piece of flat stock in the 72-tooth bull gear to index the 72 cuts. I also changed the method of adjustment just cuz I wanted/liked it that way.
Wickedbass
Just North of Boston
Sorry for the delay- but here you go.
Let me know if you need more.
P
pjaf
Thanks Wicked
What you and Michael sent me is perfect
I’ll be sure to post my results when I’m finished
Thanks to all who has helped me
