I need help taking craftsman model 113 22521 sander apart to replace the proximal roller
C craig engles New member Joined Oct 4, 2023 Messages 4 Oct 4, 2023 #1 I need help taking craftsman model 113 22521 sander apart to replace the proximal roller
N nadogail Well-known member Joined Jan 23, 2009 Messages 32,228 Location Coronado, CA Oct 4, 2023 #2 Are you anywhere near my workshop? If you are I am available to assist you.
N nadogail Well-known member Joined Jan 23, 2009 Messages 32,228 Location Coronado, CA Oct 4, 2023 #4 I don’t imagine you will be bringing your sander to my workshop so I can see how I can be of help. Good luck on finding an instruction book for your Sander
OP C craig engles New member Joined Oct 4, 2023 Messages 4 Oct 4, 2023 #5 I have removed the two Allen head screws that screw into the keyed shaft. I have applied wd-40. The shaft doesn’t move easily with light prying. Any suggestions on removing this disc attachment from the shaft on this craftsman sander.
N nadogail Well-known member Joined Jan 23, 2009 Messages 32,228 Location Coronado, CA Oct 4, 2023 #6 WD 40 is a water displacer, and is not intended to be a penetrating oil. Try Liquid Wrench or Kroil.
