Craftsman 12mm Wrench Comparison (USA)
wyattstihl
So I decided to do an at-a-glance conparison of some of my Craftsman American made wrenches, starting with the old to the new. I compared, for the most part, stampings, thickness, and overall quality. Not sure if anyone cares about what I saw, but if you are, heres what I found.
I used 12mm for this.
I started with the oldest, an Easco made Craftsman (VV), then to an old Danaher (V^), then a new Danaher. (Old v^ as in 1980ish, new as in around 2010.)
As you can see, the Easco VV wrench (On the left) is much thinner and more rounded at the edges, and the box end was forged with its angle already determined. Also, its open end is the slightest bit longer. The stampings were clearly determined in the steel.
The 80’s Danaher V^ wrench is slightly thicker, but still somewhat rounded on the edges. Its stampings are very much clear and determined. But, the box end was bent to its angle instead of being forged so.
Finally, the 2010 Danaher wrench. Although shiny, its stampings are good, not as determined as the previous wrench. The wrench is very thick, and looks as if it was passed once through a grinder and sent down the line. The box end is also bent into shape.
As you can see, Craftsman quality became worse and worse as time went on.
Not very scientific, but definitley they weigh more the newer they are. I havent bought a Chinese wrench to compare to these, but I would be interested in hearing what you fellas think.
Thanks, Wyatt.
Ohmthis
Outside of Louisville KY
While I appreciate you taking the time to do this comparison, end use has always been more important. I have Craftsman from the late 80’s until 2008 or so. They’ve always done the job I’ve asked them to. It seems most everything has gotten worse as time has gone.
Jeremy77
Coastal Alabama
In my opinion, they all look about the same. Have any of the three ever proven troublesome at turning a 12mm bolt?
W
wyattstihl
No, can’t say they have. Just got bored in the shop, thought I would take a closer look at how they may have changed. My original post seemed to have a negative feel after rereading it, but IMO they are all good tools.
I do have to say, on some newer Danaher wrenches from the late 2000’s I have noticed lots of the box ends are unevenly bent, some angles being more and less than others. Just a thought. Not that it really matters, but its something I noticed.
Jeremy77
Coastal Alabama
I’m curious to see if Stanley keeps the classic raised panel design that many manufacturers have made for craftsman. It’d be nice if they offered a longer version in its place. The short length is the only issue I’ve ever had with their wrenches.
4xdog
Santa Fe, NM
How can you tell the bend in the early wrench was forged in and the later wrenches were done post-forging? It's in a different place, yes, but it seems like either design could have been forged in or bent in.
AmishFury
one of my main observations with older vs newer USA craftsman RP wrenches was the edges of the beam on the wrench got less rounded over the years
i have old RP wrenches that are just fine to use all day long and i have some newer wrenches that were not even nice to hold in the hand and needed some deburring to be something i'd even consider using
never handled any of the chinese RP wrenches
Tallpilot
Orlando
The biggest annoyance of the later Craftsman wrenches was the wrench openings were not deburred and had sharp edges.
That's the big deal. With each generation they became a little cheaper to produce but less comfortable to use. Cui bono?
sberry
Brethren, Michigan
I am not a history buff, I would say the old one was 70's make and the new one is 81. The old resembles SK. I have some of an old set, some got left in tractor boxes over the years but they have a very fine box and different head.
Skin
Boston
The box end is offset to the beam as opposed to the beam being bent.
