Craftsman 150 Drill Press - Just Starting Out
dcpugh
New York, NY
Hi All - A couple years ago I acquired a very nice, functional Craftsman 150 Drill Press. I think it's from the late 1950s or early 1960s. It runs pretty smoothly and seems to be in good shape overall.
However, I can't help myself and I want to do a restoration on it. I'm seeking some advice on a few things:
1. How should the quill gasket be fitted. Right now, it's just floating on top of the quill itself and I'm not sure where it goes. Also, where should I get a new one? You can see in the attachment that it's just loosely sitting there. It's also pretty crusty and brittle.
2. What's the best place to mount a power switch? There is none now. If I wanted to drill into the headstock for a small toggle switch, how would I do that?
3. Is there any technique to not have the table or headstock drop like a stone when I loosen the clamp arm for either. I almost lost a finger the other night when I was cleaning it.
I will post more pictures as I get started on the project, but wanted some early thoughts from the forum.
Thanks!
Dave
Cruzan80
Denver, CO
The nice part is these are very easy to clean and refurbish. Getting the table/head to stay when loosening is an acquired skill. The best way I can describe it is to put upward pressure on one side, causing it to / against the pole. Works much better with the table instead of the head. Various people have replaced the quill gasket, and a search will turn up options (IIRC, ZJiggy's thread had options). Mine has an outlet box bolted to the outside of the motor, and someone had drilled a pressure switch into the side of the head (possibly for a lamp)? Various people have engineered options on how to power them with a switch.
CalsXS2
I wouldn't drill a hole in the head for a switch. If it has the original motor, there should be a spot for it in the base of the motor.
D
dcpugh
New York, NY
Thanks all for the replies! Much appreciated and I feel most welcomed to the forum. I will keep the board updated with my progress!
Cheers
Dave
