Craftsman 175 PSI Compressor
Rlstephens297
My problem is that I have the loose hose that I don't know where it's supposed to connect. This hose is also stopping my compressor from building up enough air to do any work. I am also looking for any documentation on this air compressor. Anything from diagrams to the owners manual would be helpful. If anything else is needed to get me help, please let me know and i will get it.20240709_195638.jpg20240709_195651.jpg20240709_195700.jpg
In the attached pictures I have the information about my compressor and an image of the issue.
jblnut
In the Middle of MN
Looks like a push to connect fitting that **** it’s guts out. It belongs in there. Time for a new fitting. Time to hit up Amazon once you figure out what size it is. My guess is it’s a 1/4” NPT X 1/4 push connect. Take it off the regulator and see what it is.
R
Rlstephens297
Okay thank you. I will try that.
NUTTSGT
Northern Central Ohio
Yep, that's my thought as well.
Might have to do some disassembling to swap out the fitting for replacement.
R
Rlstephens297
Thank you for the help. I was able to find a replacement for the broken piece and a replacement hose that comes with the needed fittings.
