craftsman 50145 floor jack
Jakerot
Yes
hello all. I got a craftsman 50145 floor jack Chinese leaking from around the pump. Been reading and reading the last few weeks and can't seem to find another having the same issue. Read hiball FAQ but didn't see this issue mentioned.
Replaced a pump o ring yesterday and it appears to no have made any difference, so I decided to post the symptoms and what I have done and maybe someone with similar issues can chime in.
First off I have read these Chinese crapsman floor jacks are not the best. The one I got is probably 15 yrs old and I think it acted up most of the time I owned it. Not helping the issue is I didn't really use it often and it would sit for years between uses.
So it leaks from the plunger area as far as I can tell. However it leaks only when not in use. I bleed and bleed until I get no pssssssss sound at the fill plug. Other times I would bleed with the fill plug off. Bleed until oil doesn't overflow from fill port and no air bubbles come out. Then I use the jack and push the fill plug with a screwdriver after use and the thing pops off due to air pressure.
The jack lifts up fine. Doesn't feel spongy. Lifts to like 19 1/2" before safety valve opens. Will hold the load with no noticeable lowering even after 12 hours under load. No leaks at this time.
Using autozone Jack oil.
But after I lower it, it seems like the reservoir is pressurized and is forcing oil back through the check valve then past the o ring in the plunger.
If I push the fill plug to get the psssssssss then the leak past the plunger stops.
So my guess is the high side of the jack is ok, but something is going on with the low side. Sucking in air from somewhere? But where? The plunger? If so I would expect to see oil leaking during the compression stroke of the plunger, but I don't. Also, if it was sucking in air I would expect it to feel spongy which it doesn't. Lifts up the front end of my buggy in 8 strokes or so, no leaks, not spongy. The trouble arises after I release the jack and store it. Oil starts to oose out the plunger slowly.
I replaced the plunger o ring with one from an o ring kit. Looked like a match as best as my eye could see. Fit in the plunger groove and was a little snug on the plunger OD so I thought I found my problem. Replaced o ring, bled, jacked up load. Let sit an hour. Released. Then started leaking again. Btw the load I am lifting isn't anywhere near the 3.5 ton rating on the jack.
Before I chuck this crapsman Jack I figured I'd post to make sure I didn't miss something. Will start looking on CL for rebuildable us made jack in the meantime.
If the issue is with the check valve then I'll probably scavenge the hardware off this POS and chuck it. Haven't messed with them by the way.
Also tried Bigfoot bleed method too. Didn't make a difference as far as I can tell. Read this will help dislodge any stuff that might get into the check valve.
Sorry for long post. Thks for everyone's help.
rburke65
Canfield, Ohio
I don't know the model number of mine.....have owned for..?..15 years guessing. I think the second time I used it the seals blew out. Was able to rebuild it with "O" rings from work. Made in China....I guess I got for what I paid. It's been since ok. I know this isn't much h LP but it's a large club of which we belong.
J
Jakerot
Yes
Well I made some progress today I hope.
Replaced o ring for release valve. Then I lifted a load and released. Looked for leaks. Clearly saw it was coming out from the flat head screw on the left closest to the plunger. Released air from cylinder and leak stopped.
I removed that flat head screw, marking its location first. Replaced o ring with closest I could find. Pumped up load, lowered. Saw it was leaking from same flat head screw
So that screw has a note do not adjust. Well I adjusted it. I tightened the darn thing until it stopped leaking.
Bled some more air by pumping handle 20 times, then pry fill plug with screwdriver to release air.
Lifted up load, then lowered. Watched, no leak. So I lifted up a load again and lowered again, no leak. Could that be it? Time will tell.
