Craftsman 950168 Floor Jack Handle Assembly
poster79
There’s two bolts that hold the handle in place. I’ve managed the grind the threads right off the longer bolt that goes into the spring. I’m looking for info on what the bolt is called and where I could find one. Any help is appreciated. Thank you
The Cobbler
I would probably call it a set screw .
how did you manage to grind the threads off?
probably match the threads , get a bolt & grind off the threads on the end like the original was
