Craftsman BE "plug" ratchet back from the dead . . .
Jim_No_Garage
Millington NJ
Folks:
Several years ago I bought a tool box that had a 1/2" Craftsman BE "plug" ratchet in it. The ratchet was rusty and locked up. I tried soaking it to no avail so it sat in the toolbox till today.
I saw it sitting there and decided to open it up and see if I could get it working again. The reason it sat so long was that it is riveted shut - no screwed together like the 1/4" companion in the box.
I drilled out the rivet and popped it apart. There was a teaspoon full of powdered rust in the chamber and the pawl was frozen to the cover by rust. I cleaned everything up quickly and reassembled it with an 8mm bolt for now.
It ratchets nicely but it's still UGLY from the rust.
I don't like bolting it back together but I'm not sure I have the ability to rivet it shut again. Any input on sourcing appropriate rivets?
Pic #1 is the "pretty" side of the ratchet - this side was facing up as it lay rusting in the bottom of the toolbox.
Pic #2 is the "ugly" side of the ratchet.
Pic #3 is an image of the internals - still dirty but functioning. I will clean the sprocket better before final assembly.
PS : Any source for a 1/2" plug so I can use this with my vintage Craftsman BE sockets?
Cheers
Jim
Cruzan80
Denver, CO
Nail. Hit the end with a small torch for annealing, and then peen down. Used to use roofing nails when the price of copper skyrocketed.
Sent from my VIVO IV using Tapatalk
Dan in Pasadena
Pasadena, CA
Is there such a thing as a Chicago screw large enough to do the job?
Less hassle than finding/installing a rivetand better looking than a conventional bolt.
I'm not a "patina guy" so I'd hit each part of the ratchet with a brass wire wheel on my bench grinder, lube it well and put it back together. I think it would look good.
If you have a hole large enough for an 8mm (5/16") bolt to pass through, I would think you'd be able to find a threaded fastener with flush heads on both ends that would work. I know they're made, but I cannot recall what they call them.
I found one this evening for a 3/8" square female drive ratchet, and it was not cheap.
I found two for 1/2" square female drive ratchets, and they are even more not cheap:
Walden Worcester 1135 5-inch 1/2" square male/male drive extension
well used. detent balls both ends.
$17.01 + $3.25 shipping "buy now"
http://www.ebay.com/itm/Vintage-5-W...245838?hash=item4b090abcce:g:iKAAAOSwaB5XjpPv
Walden Worcester 1109 1½-inch 1/2" square male/male drive plug
$29.99 incl. shipping "buy now"
http://www.ebay.com/itm/Vintage-Wal...654816?hash=item2ef7e7bba0:g:OR0AAOSwdzVXi9-I
and for those of you reading this who might be in the market for the same item in 3/4" drive:
Walden Worcester 8-inch 3/4" square male/male extension
$14.99 + $15.50 shipping OBO "buy now"
http://www.ebay.com/itm/WALDEN-8-EX...773718?hash=item35ea284296:g:U1AAAOSwBLlVVLfO
I am still looking for a drive plug adapter (male/male) for 1/4" square drive and 1/4" to 3/8" square drive.
Maui
Upstate NY
If you had a lathe handy, you could custom make one that would solve the problem easily.
Maui
Bruce Lancaster
Or try a carriage bolt re-enlisted as a rivet...file down the corners so it fits in snugly, cut it so maybe a little more that 1/4" sticks out, set the tool down with head of carriage bolt against anvil or any decent chunk of steel. Start tapping the protruding end with a hammer, not too hard...move your blows around outside edge, and strike it in the middle too. You will see the metal moving, carry on adjusting locations of blows to make a reasonable mushroom rivet head. You will find this to be very easy. Best, but not necessary, will be a bolt with unthreaded shank on what you use, but fully threaded ones are easier to find and perfectly OK.
I think any store-bought carriage bolt will be fine...I don't believe they come in aerospace super duper grades!
hemifalcon
Union Grove, Wisconsin
How about just trying to find a metal rivet at the local hardware (NOT big box store) if you have one local.. Play around with trying to heat it up with a torch (mapp may work fine if you don't have acetylene) and buck it like original??
northwoods
Minnesota
Get some pix from the bay to see just what you want.
Then go to Ace Hardware or another comparable.
You might get lucky.
J
Jim_No_Garage
Millington NJ
Wow - this is why I love this place.
All sorts of help with approaches to fixing this ratchet.
I'm going to go to the 2 really good hardware stores this weekend and see if they have something like the Chicago Screw mentioned above. Plan B would be finding an appropriate rivet or bolt to form into a rivet.
I will post again as I wrap this up.
Cheers
Jim
^ I would definitely go with that "*** bolt" deal as opposed to a rivet. That way you can easily get back inside the thing. I don't think the fastener holding the cover plate over the business end of the ratchet needs to be able to withstand some tremendous torque load - it just holds the thing together. Why would an aluminum fastener not work?
J
Jim_No_Garage
Millington NJ
I found what I needed today at Hardware Store #2. The ratchet is all buttoned up and back in the drawer with it's brethren. I have a 1/2" plug on the way from a member here.
The look isn't as vintage as I wanted to match the ratchet - but it's reversible in the future if I find something better.
Cheers
Jim
COL911
Virginia Beach VA
Jim, do you need any Craftsman BE sockets? I have some with great patina I got in a box lot that I would let go cheap to a good home.
J
Jim_No_Garage
Millington NJ
COL911 - Don't get me started . . . You just forced me to go down and line up my BE Sockets and see what I'm missing. If I mix BE and =V= stuff I'm pretty well covered - except that I need a 3/8" BE ratchet and a plug for my 1/4" ratchet - where does it end?
Thanks for the kind offer - I'm good for now - but if I change my mind I'll PM you.
Cheers
Jim
