Craftsman Block Grinder Part-out
Leadberry
Akron, OH
Akron, OH
I am putting out parts for a couple CM block grinders. All parts ship from 44314. Local pickup is OK.
NOTE #1: Please be patient with me. I am a full-time engineering student and work part-time, so I may not get back to you right away. I will answer posts and PM's in the order they were received.
NOTE #2: I do not want to separate parts any more than I have here. I have tried to balance the need for affordable replacement parts with my desire to not have anything left over. I'm no hoarder!
NOTE #3: *IF YOU ARE BUYING THE WHEEL GUARDS* Not all block grinders use the same shaft length! These came off of a grinder with a 15 3/4" shaft length. If you aren't buying these for a model no. 397.1949, it is up to you to make sure these guards will work with your grinder. These should fit other models if you buy the shaft as well.
397.1949 7" 1/2 HP COMMERCIAL, DUAL VOLTAGE
P/N's HERE: LINK
Castings, Main Housing
Free, you pay shipping - RH housing is cracked and bent at the base. LH housing is in good shape.
Castings, wheel guards (exhaust type)
$20 + shipping - in good shape. Comes with bolts to secure to main housing and screws that secure side covers. SEE NOTE #3.
SOLD Steel tool rests
$10 + shipping - in good shape, complete with fasteners.
SOLD Plastic eye shields
$10 + shipping - in good shape. Still have good clarity, not too yellowed or scratched up. Just need wiped down. Complete with fasteners.
Rotor w/ shaft, wheel flanges, and jam nuts
$15 + shipping - in good shape. Bearings need replaced. 15 3/4" length.
Main housing cover plate w/ name plate/sticker
$5 + shipping - some slight rust, could use a repaint. Sticker is in excellent shape. No switch.
397.19590 7" 1/2 HP INDUSTRIAL RATED, DUAL VOLTAGE
P/N's HERE: LINK
Stator
$10 + shipping - blue wire has rotted insulation; liquid electrical tape has been applied to protect exposed copper. Could use some heat shrink tubing. Otherwise in good shape. Pulled from working grinder. 4.4A @ 120V.
Start relay
$5 + shipping - in good shape. Pulled from working grinder.
Start capacitor
