Trying to restore a toolbox. It seems in good shape except for the rust. Needed know a spray paint that would be close to original.
Which is the better match for the red and hammertone Waterloo tool cabinets. I haven't used it yet but the cap on the Rusroleum can I bought looks a little dark.Members have used Rustolium Hammered Grey or Hammered Silver for the lighter boxes. I don't think there's an exact match for the older darker grey, so the Hammered Grey will likely be the closest you can get without having a custom paint mixed up.
The only problem is that it is bare steel and the best you can do is spray on some rust protectant or clear coat. I have seen some home zinc plating jobs online that took on a really nice shine and are better protected. I really want to try that.You will be surprised how well that hardware cleans up. Thy a fine brass brush on a dremel tool if you need to leave them attached. Then you can use fine sandpaper to smooth out some of the more rusty spots. Get it down to clean metal, then polish with a wheel, or try some polish in a jar like Mothers. I prefer Hapich Semi-Chrome polish in a tube, but use what you have, or can get. Here are a couple I took off and polished with acceptable results. Lots of sanding was involved.
Almost finished the one on the right in this picture.
Jewlers rouge. Looks nice.I just polished the bare steel with a bar of that red polishing compound. I think it will hold up, but a coat of wax should help too.
