Craftsman compressor might be toast
JABgj
So. California
I have had this compressor for a long time, bought it new. Model number 919.152931. It is an "oilless" unit and needs a new set of pistons and sleeves and unfortunately, they are now obsolete. I think this unit is on it's 3rd set. Spent some time searching the innerwebs for parts and no luck so far. Anybody know of a secret parts source or workaround for these units?
Being cheap and broke means I can't run out and buy a new replacement. Your input would be appreciated.
J
JABgj
So. California
I actually have a set of new rings and the "sleeves" might be workable if I clean them up and polish them. The rub is the 1 piece piston/conrod. 1 is broken, which is common and the other is OK but who knows when it's number is up. I also need a fan which is available.
J
JABgj
So. California
Ryan, thanks for checking. I looked at that site as well as others using the Craftsman number and the part number for the piston assembly. Those sites show the part as obsolete. The search continues and options are being explored.
American Locomotive
Rhode Island
My take: Throw the compressor out and move on. You claim you're cheap and broke, but how much has this compressor cost you will all the rebuilds it has needed? It blew up so bad that it destroyed the rod, cooling fan, the sleeves are worn out, etc...
Time to move on. It's costing you more than it's worth. You could pick up one of the compressors Woody linked for about the same amount it'd cost you to rebuild your compressor. And being a homeowner, those iron pumps will probably last you until you die.
J
JABgj
So. California
I have to agree with finding a cast iron oil bath unit would be the ticket and has been considered. Used to be parts were cheap and plentiful too and worked for my needs. No reason not to look for a replacement but if I spend 3-5 times the cost of parts on a used oil bath machine or buy a new lower priced unit, I am not sure how it will work out.
driftpin
Buy something new, when you can. The Harbor Freight compressors with the Italian-made pumps have gotten good reviews on GJ.
Save your current tank, and turn it into a reservoir, use quick connect 3/8" size fittings, and you'll have a portable tank, and extra capacity for your new compressor.
Here is one which is an oiled unit:
https://www.harborfreight.com/21-gallon-25-hp-125-psi-cast-iron-vertical-air-compressor-61454.html $150
Air delivery: 5.8 CFM @ 40 PSI, 4.7 CFM @ 90 PSI
Heavy duty 2.5 horsepower rated motor
Long-life oil lubricated compressor with precision machined cast-iron sleeve
Single capacitor motor with thermal overload protection
Wheel kit with 6 in. wheels and ergonomic handle for smooth portability
Oil level indicator window for easy maintenance
Reduced vibration with rubber foot stabilizers
Built-in quick coupler for convenient air hose connection
VolvoRyan
Kentuckiana, USA
My bad. I assumed that the cylinder kit was all-inclusive, which is how they're sold for my upright.
How old is this unit?
-Ryan
J
JABgj
So. California
Ryan, good question. This one is at least 25 years old so obsolete parts should not really be a shock to me. Driftpins suggestion of the HF unit got my attention and I really did not consider HF because of my old policy of being cautious of anything from HF if it gets plugged in. The suggestions and help here are good and have got me to rethink my air needs so we will see what shakes out.
driftpin
Try the warranty if you decide to buy the HFT unit, if it lasts a year in frequent use, you'll probably get long use out of it. I've heard it said that if an electrical appliance is going to fail, it's going to happen quickly, assuming that you aren't abusing it, to force a failure.
In-defense of HFT corded tools:
I bought a new HFT SDS-MAX hammer drill demo tool for < $90 on-sale, it paid for itself on the first job I bought it for, demo'ing two bathrooms, and while I don't use it frequently, when I had to set some threaded 5/8" drive-pins for fastening PT 2" X 6" footer plates to a concrete slab, it did the job quickly while a DeWalt battery-powered hammer drill couldn't do the job, at-all. I think Harbor Freight has some good products, and for me, this was one of them. BTW, I have a corded Milwaukee Holegun hammer drill, and for the footer plate job, I didn't even-try to use the corded Milwaukee. I reached for the SDS-MAX HFT and did the job.
tarbellb
Oregon
How much did the rebuild typically cost you? I bet you have the process down, how long to rebuild?
J
JABgj
So. California
Can't quite remember what the parts used to cost and there are no current prices. A guess for today's prices would be about 60.00 per kit for seals, sleeve and piston and 2 kits are needed for a full rebuild and I need a fan assembly which is another 15.00. After looking at the damage I think I can get it going again if I can find 1 piston and buy a fan, but if it goes again and there is no change in the parts availability, she's a paperweight or a nice big portable air tank.
The rebuild is pretty simple and it can be done in less than 2 hours if I take my time and service other things as I go.
95vette
Hello,I have a used piston rod and sleeve with bearing part no. acg -1,counter weight acg-6,and bolt acg-8, that look good, you can have for shipping. Send me your address and I will put in small box and mail. Jim
tarbellb
Oregon
Wow. $120 per rebuild. Youve already paid for a newer, nicer unit.
If you can pull it off with the current stock, go for it I guess. But there a whole new batch of "quiet" compressors in that cfm range that can be found for <$200.
Check out HF, Lowes Kobalt series, California Air Tools (CAT), and a few others. Or a very nice oil splash, rebuildable unit are the Makita MAC series, but more $
J
JABgj
So. California
PM sent. Thanks
J
JABgj
So. California
It's alive! Thanks to 95vette who sent me a usable rod assembly and some extra bits, the old unit is running again. Used my sleeves, 1 of my pistons and 1 of 95vette's, installed new rings and it started and runs quiet (as quiet as an oilless will run) and smooth. I am waiting for a new fan to come in, so I can't run it much, but a quick test run got it up to 60 PSI without a fuss. Still trying to see if pistons from other models will fit so I can gather up a supply of spares. With any luck, I can get a few more seasons out of it. Thanks!
J
JABgj
So. California
It's been a year on the repair and it's holding up fine. Have built up a stash of parts so I will be good for a while. Thanks again to all that chimed in, it made a difference.
Scabber
As you "built up a stash of parts", did you happen to find an additional source for substitute or aftermarket rods/pistons for Craftsman Compressor 919.152931 with Pump #:AC 0051 and Rod Part #ACG-2 ?
I'm where you started, only worse. Both rods/pistons completely self-destructed, taking the fan with them and bunging up the cylinders (these parts do appear to be still available). I have nothing into this compressor, as it was pass-on from a friend. Sadly it had set unused for too long. I can certainly make use of the very nice 6hp 220v motor and the 33 gal. tank, but if I could rehab the unit at a reasonable cost, I would.
J
JABgj
So. California
Will try look at emails over weekend to see if there is any more info. From memory it seems the only new part available was the fan. The other parts were from a member here and feePay.
J
JABgj
So. California
No useful info to share, but I did notice on eBay there are new rods available made on a CNC machine. Look them up but you have to research if these rods will fit your application. In those kits, the pin that holds the counter balance weights together is available as well.
Good luck.
