Honda-Guy
I need some info here about my craftsman air compressor. The pump is bad (knocks at low psi and takes a long time to build pressure) and needs replacing but need to know which one to get.
Specs:
1992 Craftsman 60gal 5hp 2 stage air compressor
Motor - Doerr 5hp, 15amp, 230V made in USA motor (what the label says)
Pump - 2 stage 10cfm @ 90psi pump - Last time I checked it was a DeVilbliss that was subbed out and made in Italy and the parts are NLA
The questions I have:
Is it really a 5hp motor with a 15amp rating? I thought 3hp motors were 15amp and the 5hp was 20amp?
Can I get away with running a Harbor Freight pump rated for a 5hp motor or do I need the 3hp? I don't want to push the motor if it won't handle it but i'm looking for volume as its mainly used for my blast cabinet.
Specs:
