bagged89s10
So I have a newer oil less craftsman compressor and an older craftsman compressor.
This one is about 15 years old and the tank seems pretty solid. I bought it new and usually drained it. I did drain out about a cup of some rusty water which I neglected to empty over this past year. It's just too loud.
Then I have this compressor which I picked up for $20. The 220v motor and compressor work fine and that's why I bought it. I've wanted a nice fairly quiet compressor for a while now.
Looks like someone either welded up a pin hole or the old fitting for a drain. I don't even know if these old compressors came with a petcock underneath. So it could be just a welded up fitting.
My plan is to mount the tank and compressor inside this cabinet. The oil less craftsman has been in there and fits fine
It's not air tight by any means and has vent holes. I can add more vents if I need to.
So my questions.
1.What did the bottom of the old craftsman tanks look like. We're there drain fittings underneath?
2.Do you guys think I should use the red tank with the setup of the 220 motor and compressor? If I do should I mount he motor and compressor separate from the red tank?
3. If I mount the motor and compressor off the tank, can I move the motor closer to the compressor and use a shorter belt? Or will that cause the compressor pulley to spin slower or faster?
So my questions.
