Craftsman drill grinder on a disc sander
Scimonetti
VT
Anyway, you think it would work on a disc sander? Assuming there isn't too much runout I don't see a problem. It would be nice to have a little dedicated tool that I don't have to keep setting up. The question is speed and grit. 220 or 120 grit on a 9"wheel? 3450 or 1750 rpm?
Thanks for any input!
Plombob
Tennessee
I've got one mounted on my pedestal grinder. Haven't used it in years. It's more trouble to fiddle with that thing than buy a new bit. I wouldn't worry about grinding on the side of the wheel. You're supposed to use light pressure. As for using it on a sanding disc - I expect you'll burn through the discs before you sharpen the bit.
You can see the tool in this picture on the left.
View media item 37626
