I have an older Craftsman drill press, model # 113 24630 ( first pic below), and it is missing a swing arm/hinge (whatever it is called) for the top cover. In the second picture you can see the swing arm that is at the front of the top cover, but then as you move back towards the back of the drill you can see a second set of holes where one appears to be missing. I believe it is just straight and I believe I know where it mounts on the top cover. However, if one of you has this drill press or a similar model then can I please trouble you for some reference pictures or a response so I have an idea of what to make for the rear arm. Thank you!
Edit: I did look at the manual for the machine, but it only shows a portion of the arm. I need to know its entire shape and length.
