Craftsman Drill Press Restoration Help.
kshaub103
Hello, I have a bench top craftsman king seeley drill press that I’m restoring. I am using timken 6202 for the quill bearings but the ID of the timken is not large enough to fit the shaft. Any suggestions?
Edited for correct information of the bearing​
consti2tion
East Texas
Do you have a dial/digital caliper to measure the ID of the bearing and the OD of the shaft?
Edit: according to this very informative thread you need a 6202 for quill bearings.
K
kshaub103
Shaft OD is 15.80mm
And yes my error I have the correct bearing it is 6202 I was confusing the 6205 spindle bearing that fit perfectly.
K
kshaub103
Local shop had one really nice lady looked at say looks like a 5/8 ID but let’s measure it. Came back with two bearing 6202. Installed on the quill and the machine is almost done. Thanks for the information.
consti2tion
East Texas
Those local shops are awesome, I try to use ours when needed to hopefully help keep them around.
Post some pictures of it when you are done!
