Craftsman Drill Press
sunder
IL
I made a quick video recapping how I removed the base off my drill press. I hope this helps
Link:
<iframe width="560" height="315" src="https://www.youtube.com/embed/LCsDA00B0D8" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
LesserSon
PA USA
THANKS, guys!
Excellent ideas, information, and images. Very empowering. My Evaporust soak included will end when I get home later today, and then the beating shall commence.
As far as why...a long way back, FrankLee points out that separating them opens up more options for dealing with the column. I really did consider leaving them rusted together, but for my own use, freeing them will make potential relocation easier, and if it come to parting it out, I think it makes the individual parts easier to reuse or sell.
F
FrankLee
seMI, 48317
Pink Floyd said:
Home
Home again
I like to be here
When I can
I just got home from a week in Michigan's Upper Peninsula. So much to see and do. However, my cellular service was bad and phone internet service was really bad with no wifi, so I could barely monitor and wasn't able to respond. I've got some catch-up to do.
THANKS, guys!
There is a link in my first post regarding the base and column showing several techniques on how to remove a stuck column from the base.
rickhigginshtbr
Lower Bucks, PA
Re: The Classic Craftsman 100/150 Drill Press
Dragged home a delta (odd ball 7” press) just for the table lift! From what I’ve seen, same Patent tag on this one as the one Sears sold for the floor models.
Thought I saw it before, restoring the lift, any tips? A little rough going up and down, probably cause it’s covered in surface rust.
Rileysan
Milwaukie, Oregon
Is this from a Craftsman Power Tool catalog? or the Big Book? I always thought there was no power tool catalog that year.
You forced me to double check and you're correct!
I have a copy of David Maher's digitized Craftsman tool catalogs on DVD, and I went straight to the 1958 catalog without realizing it was advertising for 1959.
To clarify things for anyone else reading this, Sears published catalogs for the upcoming year prior to that year - so a 1958 catalog would have been printed and published in late 1957.
I did find the ad for the King Seeley drill presses in the master catalog for fall/winter of 1958. I also captured the ad from the fall/winter 1957 catalog as well.
Brian
bubinga
Brian
Love those old tool catalogs.
F
FrankLee
seMI, 48317
Another excellent find... congrats!
There are a couple links in my first post about these table lifts. Members Rileysan and sheltonfilms recently found presses with the head/table lifts.
There could be several reasons raising and lowering the lift is sluggish.
  • the rust, as you mentioned
  • the old style cast lock cylinders could be sticking
    Swapping to the all-steel cylinders is beneficial.
  • the column diameters
    Even though 2-3/4" is a very common column diameter, there are slight differences of several thousandths of an inch between manufacturers.
F
FrankLee
seMI, 48317
Brian
Thanks for posting those.
So now, more information leads to more questions. I've always understood and posted that the Craftsman 150 drill press was introduced in 1958.
Both the '57 and '58 fall/winter catalogs show illustrations of a Craftsman 100 drill press. The illustrations on the pages are virtually identical. Perhaps they simply did not have new illustrations of the 150 like in the 1959 catalog.
sheltonfilms
There are a couple links in my first post about these table lifts. Member sheltonfilms recently found one. See his in post #2558.
Also the thrust bearing could be on the wrong position, as Franklee shows in this post:
https://www.garagejournal.com/forum/showpost.php?p=5137547&postcount=166
Rileysan
Milwaukie, Oregon
I'm sure you're aware it's really difficult to nail down exact dates of availability using just the Craftsman tool catalogs. Sears advertised in various publications (Popular mechanics and Popular Science, to name a couple) and published full page ads, and seasonal catalogs. It seems likely someone found the 150 in a seasonal ad/catalog from 1958.
To demonstrate my point, I was researching the Craftsman wall hanging tool cabinets and came across an interesting comment in the 1950 catalog.
"We introduced this big, handsome tool cabinet in our Fall Midseason catalog, and it proved to be sensationally popular."
Thus, we are able to derive the wall hanging catalog was introduced in 1949 even though it didn't appear in the main and specialized tool catalogs until 1950.
Brian
LesserSon
PA USA
Beginning to look like there’s nothing that ain’t broke on this sucker. I was aware of the sidewall crack, but not of the one across the back collar buttress, until the rust remover did its work.
As of yet, I haven’t found much wrong with the table, so there’s that. Until I strip the paint...
Smokeshow69
If you keep an eye out on eBay those bases pop up cheap now and then
sheltonfilms
Except for the shipping price. They got some heft to them.
F
FrankLee
seMI, 48317
Brian
Yes, very aware... and not just availability, but when changes occurred.
Your post prompted me to spend some time looking through some old magazines. I found a drill press article in the December 1958 issue of Popular Mechanics. It shows a badly "photoshopped" illustration of a Craftsman 150. So that proves 1958 availability.
Another example is the Jacobs Safe-Lock chuck. It was first advertised in the 1952 catalog as being a standard feature on Craftsman drill presses. Here is evidence from a May 1951 issue of Popular Mechanics magazine advertisement that the Safe-Lock chuck was available earlier.
(Not sure why the above 1951 link is not working, may need to cut and paste: http://books.google.com/books?id=29...39#v=onepage&q=sears drill press 1951&f=false)
So, catalogs are only one piece of the puzzle. Dated owners manuals are another, but advertising is probably the most reliable.
Rileysan
Milwaukie, Oregon
I'd be interested in seeing that article. Any chance you could scan it (or attempt a photograph)?
Brian
F
FrankLee
seMI, 48317
sunder
IL
Wow that is in great shape
JoCoSawdust
Eastern NC
I was teaching a class about 4 hours from the house, out of my hunting grounds. I have a coffee mug with a Plomb logo on it, struck up a conversation with a local guy about old tools ( he had no idea what Plomb was). Never mentioned Craftsman. He said he had "an old drill press" that was his Grandfathers that he needed to get out of his garage. I wanted to get on the road as soon as I was done so told him I'd pass on going to see it. Over lunch he went home, put it in his truck and brought it in. I put on my poker face and asked him how much he wanted for it, he asked what I'd be willing to give. I stuck with the "I want to get out of here as soon as I'm done" story and told him I had 40 bucks in my wallet. He accepted and it came home with me. I have to admit I pulled over twice on the way home to ogle it in the back of my truck.
EDIT: And yes it's in remarkable shape. Even has the original chuck key with it. The only thing not original is the wing nut on the pulley cover, should have a knurled nut on it. I think I have one I can dig out tomorrow. I'm elated!
Smokeshow69
Sigh ... you seriously need to go buy lottery tickets... or if your garage is getting full, I can help you out [emoji51]
sunder
IL
Anyone that is looking for drill presses check your local facebook market place. They have a couple with in 100 miles of chicago. This one is $22
Rileysan
Milwaukie, Oregon
I cannot express just how much I think you ****! Grats!! That is an amazing find!!!
Brian
F
FrankLee
seMI, 48317
Picked up a nice unmolested Mohawk today
Fantastic!
I just finished my 103.0305 yesterday.
F
FrankLee
seMI, 48317
Rick, any progress on your lift? What are yours plans for it?
F
FrankLee
seMI, 48317
dp#63
That's a beauty Frank!
Thank you.
8/29/2019 @ 16:00
dp#63 is another 2nd gen Emerson, model 113.24560. It's very rough, poorly repainted, missing a couple things, but the price was right. This one is a part out.
Fubar parts:
  • spindle pulley
  • motor pulley
  • return spring
  • all three feed handle knobs
  • switch
  • wiring
Good parts:
  • quill/spindle assembly
  • chuck
  • feed stop assembly (missing the lock screw, lock screw hole was re-tapped to 1/4-20)
  • motor
  • table
  • base
  • column
  • hub/pinion
  • head frame lock assembly
  • table lock assembly
  • quill lock assembly
sunder
IL
Another one in chicago facebook market place
F
FrankLee
seMI, 48317
dp#64
None yet, it'll be restored and used on my 150.
:thumbup: That's good to hear.
There are two active auctions on ebay in the $500 range and another sold for $500+. That's crazy!
8/31/2019 @ 19:20
Dp#64 is a pre-1951 13-1/2" Craftsman 100, model 103.23640; more commonly known as a Craftsman 80.
This was an odd set-up. The previous owner to the seller had this dp mounted to the wall. The table was not mounted. You may be able to spot a corner of the table in the background on the right in both photos.
9/1/2019
Re-assembled while it waits it's turn.
9/5/2019
Most internal parts from dp#64 are cleaned.
The head frame casting before and after a rinse.
9/6/2019
The motor on dp#64 is a 1/3 hp Dunlap split phase, model 115.6960. It did not run at the seller's place. It turned out that the switch was bad. The oe switch was the old style similar to a wall switch.
A thorough cleaning, a new cord, a new switch and repacked bearings allowed the motor purr beautifully again. I had to fab a new switch plate mount.
The center band was completely rusted. I sanded it and applied an engine-turned, adhesive-backed film.
9/8/2019
The base, column and table are cleaned(?) and assembled.
9/10/2019
The refurb of dp#64 is complete.
Defc0n
Fort Worth, TX
How many HP is the motor, 16 ought to be enough, but possible breaking the camels back in this case. Can't hurt to try #12
3/4 HP which should be about 560W. At 120V it should only draw 4.7A but since the cord is getting quite warm I'm still going to step it up. Like you said, it cant hurt.
sheltonfilms
Whole new meaning for Gold Paint
So what did they use the 3450 rpm motors for usually?
Table saws, planers, jointers.
Drill presses and bandsaws are the main ones that use 1750.
